My lennox furnance won't kick on .
My lennox furnance GCS16R-411-100-5P all of a sudden wont kick on . we changed the thermostate and still nothing. the blower will kick on if I switch it to auto but blows out cold air. We can hear something in the unite but it won't do anything. does anyone know what it could be ?
  • 8 more comments
  • tonkasl24 Dec 14, 2008
    yes we do.
    Well I can't see it if it is glowing . I have looked over the unite and can not see anything . It seems to be inside this box area. but it is a direct spark type igniter. the unit is about 15 yrs old. I do not have a meter either.
  • tonkasl24 Dec 15, 2008
    ok we just took it apart and it is not getting a spark at all ..!
    ok we now have spark it was human error on are part. we think it is not getting any gas through line .
  • Amber Compa
    Amber Compa May 11, 2010
    Is this a lennox pulse?
  • Ken Bledsoe May 11, 2010
    Now that you got a spark and no gas that's not good, gas valve could be bad. You will have to get a techie to come out and check. If you had a meter we could test it and determine it's fate. Ken
    The draft fan is a safety device that has to be satisfied before the spark happens. Be sure the vacuum hose is tight on the pressure switch. And tight on the draft fan. I'm suspecting the ignitor is bad. Being 15 years old and has worked perfectly up until now. Ignitor comes from the board or some device that tells it to spark.
    I guess I should have asked you is it spark or hot surface. My unit is about 4 years old and I have a sparker that lights the pilot light which in turn lights the burners.
    The next step would be the hot surface ignitor should start to glow how about that. And if it doesn't glow do you have volt ohm meter?
    do you hear a pre fan
  • 625 Answers
SOURCE: Unit will not blow cold air after starting up for first time this season
you may need to remove the rear cover to examine what is and is not running. once you remove the back, start up the unit on a workbench. see if the fan is running and the compressor has kicked in. look at the larger or two tubes coming out of the compressor. if it is cooling a small layer of frost or condensation will appear on this " suction" line. if this tubing and the other one are approx the same temperature, then there is a freon leak in the system. Only an EPA certified technician can fill your unit. I am not familiar with that RED button but it mat be a reset of some sort. With the back removed see how it is connected in the wiring circuit. if you have the wiring diagram, please send it to me under my regular email address and I'll walk you through the troubleshooting procedure.
Posted on Sep 02, 2007
  • 4 Answers
SOURCE: Amana Air Command 90 - Model GSC075A30A
water should never reach the nipple for the pressure switch tubing on the IDM. Check the entire condensate drain system for obstructions. Verify water makes it from the furnace location to the outside drain. Flush p-traps and any anti-siphon devices thoroughly.
Posted on Apr 07, 2009
  • 3433 Answers
SOURCE: AC unit turns on blower doesn't come on
The thermostat is the controller.
Posted on Jun 19, 2009
  • 38 Answers
SOURCE: lennox air unit not blowing cold air
your fan motor outside is going bad, have a service company change it out for you.
the motor stopped working and that overheated the compressor shutting it down on thermal cutout, and it will only come on once it cools down
Posted on Jul 01, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Posted on Jul 06, 2009
My ducane furnance blower wont ignite the thermost t keep going off
The blower requires proper voltage, I will include a diagram however if not familiar with power I advise against trying any repairs.
Mar 04, 2014 | Emerson Lennox Ducane Armstrong Furnace...
Need the year of my furnance, have the model and serial number
manufacture can tell you year. what brand is it? goodman? my guess is 97 dec.
Feb 26, 2014 | Emerson Lennox Ducane Armstrong Furnace...
Heater heats but shuts off
Try the fan in the ON position on the thermostat, do you mean the fire shuts off or the blower?
Jan 15, 2013 | Emerson Lennox Ducane Armstrong Furnace...
Do you know if they purged the gas lines? Sometimes when the meters are changed air can build up in the gas line
Dec 07, 2012 | Heating & Cooling
My furnace and blower wont work but my pilot light is lit
It could be a number of things. Relay, transformer, bad motor, you either need a multimeter with a tiny bit of knowledge in order to track the voltage and find where it is stopping or a professional. Good Luck!!
Apr 30, 2017 | Heating & Cooling
Lennox intermitent flame problem
Yes the flame sensor is not allowing the ignitor to start, you will need to remove the flame sensor, and clean the black carbon build up from the stem of the flame sensor, replace the flame sensor and turn the furnance back on, this will correct the problem.
Dec 10, 2009 | Heating & Cooling
Carrie Furnance will not power up. When I turn my thermostate to heat or off it goes blank. It works on central air. I checked the breaker and it is on. I made sure the switch is on at the furnace. There...
if under warrenty DONT MESS WITH IT call hvac co out WORST THING IS TO GO TO A CALL were harry home owner has pulled stuff appart n got wires crossed makes the techs job un real ive walked on basket case calls like this i dont build em just fix em as for waTs up if u got fan on with ac and nothing on the heat and stat blanks out im leaning toward either a stat issue or a fnky board......i
Oct 05, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Progrmmable Thermostate
Check to make sure you have pm or am set correctly. Or reset everything. ??? ;)
Dec 13, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
243 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
