Question about Toshiba 53HX71 53" Rear Projection HDTV-Ready Television
53hx71 toshiba Hi I have a problem with my tv. last nithe I turn off like allways, but today when I try to turn on again the tv no works. I unplugged and whait for some time whe I reconnect loks the tv will urn on but after that the tv still like in stand by, the little red light in the front pane stil blinking Please if some one can help me with this thank you Jl
  • SMASSERA Oct 05, 2008
    I JUST HAD THE SAME ISSUE AND NOW I'M LIVING IN BRAZIL. IS THERE SOMEONE THAT COULD POINT THE SPECIFIC COMPONENTS PART NUMBERS THAT I COULD PROVIDE TO TE TOSHIBA CUSTOMER SERVICE?
I had this problem and paid a repairman to fix it. He said he has seen it often in this model, and immediately repaired it. It works now. He replaced two 18 pin switching modules, about a 1/4" x 2" x 1"; and 3 "micro-caps"(fuses?). It took about 45 minutes and cost over $400.
Posted on Jul 04, 2007
Toshiba 53hx71 blinking red light when p83 to p803 is connected
I have a 53hx71 that is haveing an issue with my blue on covergence. I have replaced both the chips and it still wont move up or down when i try to adjust manually and the auto adjust wont work either can anyone help?
Dec 08, 2013 | Toshiba 53HX71 53" Rear Projection...
My Toshiba 53HX71 takes about 20 minutes to "warm"
This is a symptom of poor solder connections inside the set. The set will continue to deteriorate until it won't turn on at all. This is essentially a labor only repair and should not be to expensive for any TV service shop. Once this has been repaired, the set should work for many years to come.
These poor connections are caused by the continual heat/cool cycles because of use and is normal.
Dan
Apr 09, 2011 | Toshiba 53HX71 53" Rear Projection...
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
Convergence issue Blue not convering correctly, but the other colors do. The blue is warped at the top and bottom of the screen. Is this problem something that can be fixed?
Yes,the covergence ICs and precision resistors can be replaced to rebuild the area. A reputable shop may charge around $300 . If you are technical person,I can guide you further to do yourself!
Jun 04, 2010 | Toshiba 53HX71 53" Rear Projection...
I've got a toshiba 53hx71 that the screen rolles when the tv is on in the video inputs or the ant inputs. when there is nothing on the tv it has red squigle marks on the black screen. When you watch a...
Most of the time the Hyper Board failing is the cause of this problem. It will eventually get worse where it also affects the HD ins. Unfortunately the Hyper Boards are no longer available from Toshiba and have not been available for quite some time. My suggestion is to coast with it and replace the Set when the HD ins fail.
Sky Assoc
Nov 24, 2009 | Toshiba 53HX71 53" Rear Projection...
How do I remove the screen of a Toshiba 53HX71. I
You do not remove the screen on that TV. Doing so will mess up your convergence.
Chassis must be removed by a professional.
Call the manufacturer to find you nearest authorized service center.
Mar 24, 2009 | Televison & Video
Picture goes away
hyper module and video prossing unit faulty
Jan 20, 2008 | Toshiba 53HX71 53" Rear Projection...
Problem with y toshiba 53hx71
Tito,
There is a fairly common problem with those symptoms. Try removing the srs-wow board, stand-up audio board next to the tuner. If the picture clears up it's likely QD01 on the srs-wow board loading down the scl & sda lines. QD01 is an Njm1136d Toshiba p/n# 23009142.
Bill
Dec 01, 2007 | Toshiba 53HX71 53" Rear Projection...
53HX71 Replaced STK392-110 about 7 months ago worked well..now convergence failed again
Thermal compound should be used SPARINGLY for maximum effect. There should be enough to create a thin film over the entire mating surface. Too much compound reduces the heat transfer from component to heat sink. I buy parts from www.mainelectronics.com They are reputable and I can drop by on my way to work :-)
Apr 23, 2007 | Toshiba 53H71 53 in. Rear Projection...
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Toshiba 53HX71 53" Rear Projection HDTV-Ready Television Logo
175 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
