Carrier moded 25HBC330A300 won't start, fan won't start either, not cooling
Needs a new capacitor
Thanks. Talked to a buddy last night and turned the unit on and used a stick to kick-start the fan and it took off. Compressor didn't though. I think you're right, not enough voltage / current output coming out of the capacitor to get the unit going.
Capacitors are pretty cheap you can get a new for about $7 just make sure that th voltage and microfards are exactly the same the micrfards can be higher but not lower than the one currently on your unit. If your compressor still doesn't come on after you replace the capacitor try a hard start.
Sorry, what is a hard start?
Its a charge that unbinds your compressor it connects to the capacitor
SOURCE: air conditioner
I managed to find the people who supplied the unit, it was still under warranty, and they said it was the thermistors (temprature probes, they replaced both of them) It is now working perfectly!
SOURCE: Sharp Air Conditioner. Model
If you set you r AC to FAN mode the unit will not cool, it only runs in the indoor but the outdoor will off. If you set to AUTO the unit will cool but the indoor blower will automatically run slower when the room is cool or attain the room temp. setting. If you set it to COOL the fan speed is fix depending on your setting and it also operate in cool.
SOURCE: Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
SOURCE: "cool on " flashing..no heat or cool air blowing
when its flashing its in a 5 min delay mode if you wait 5 min and still flashing you may need a new stat. but give it a full 5 min.
