Question about Pentair MINIMAX MODULE, IGNITION CONTROL
89 chrysler 5th avenue ingnition module location
I just need to know where it is i cant find it
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
Your "module" is part of the distributor on that model. You have an ignition unit on the drivers side wheel well just in front of the firewall. Has a triangle kinda shaped harness. Only two things
Posted on Sep 21, 2009
Where is the engine control module on a 1987 Chrysler Fifth Avenue
I had an 89 New Yorker, and the computer was in the engine air inlet duct on the left fender well. As I remember, it wasn't too hard to get to once I found out where it was - only two or three screws and the connectors.
Jan 30, 2017 | Chrysler Cars & Trucks
1989 5th avenue, idling problem
Stalls While Braked or Braking and While Turning.
www.2carpros.com/.../1989-chrysler-5th-avenue-stalls-while-braked-bra...
Jan 9, 2012 - 1989 Chrysler 5th Avenue • 89,000 miles ... Check the idle air control motor, EGR and PCV valves-also check the ... The 318s used in the Fifth Ave were built to really tight tolerances compared to those used in trucks and vans. ... and using a cardboard gauge to see if the floats fall down to the proper setting.
Sep 08, 2015 | Cars & Trucks
Where is the location of a headlight relay on a 1993 Chrysler New Yorker 5th Avenue?
Called Headlight Timer Relay located Above Glove Box On Relay Module.
May 12, 2015 | Chrysler Cars & Trucks
We have a 1989 Chrysler 5th Avenue, it is not starting. We have checked all the wiring and replaced the battery, the Timing chain, retimed the engine, regabbed the spark plugs, Nothing seems to want to...
your throwing all these parts at vehicle need to break it down --does vehicle turn over ---doest it turn over and no start --is it getting spark --is it getting fuel --with no spark need to test componants or adjust --with no fuel need to test fuel system fuel pump-filter etc
Jul 14, 2017 | 1989 Chrysler Fifth Avenue
Need firing order diagram, for a 1988-89 chrysler fifth avenue
1989 Chrysler Fifth Avenue 5.2 liter V-8 VIN "P" 2-bbl
I hope helps; remmeber to rate this answer. Good luck.
Sep 29, 2010 | Chrysler Fifth Avenue Cars & Trucks
1987 chrysler fifth avenue 5.2 engine 8 cylinder firing order
need a firing order for an 84 chrysler 5th avenue 8 cylinders
Aug 25, 2010 | Chrysler Fifth Avenue Cars & Trucks
Were is the factory amp location in my 1987 full size chrysler 5th ave.?
ALTERNATOR AMP IS STAMPED ON SIDE HOUSING OF ALTERNATOR ABOVE THE PULLEY.IF THAT WHAT YOU MEAN.
Jun 27, 2010 | 1987 Chrysler Fifth Avenue
I need a passenger side front fender for a 1984 Chrysler Fifth Avenue. I can find one on a 1985 model. Will it match?
The rear drive 5th avenues where mostly unchanged during their lifespan. It should bolt up the same.
Jun 13, 2009 | 1984 Chrysler Fifth Avenue
1989 Chrysler 5th ave, shuts off when idling, hard to start,
remove the gas tank sending unit and replace it with a new one or new filter end and your problem wiill be solved
Apr 16, 2009 | 1989 Chrysler Fifth Avenue
Pentair MINIMAX MODULE, IGNITION CONTROL Logo
64 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
