Question about Logitech PlayGear Amp for PlayStation Portable
I have an Playgear AMP logitech speaker,One speaker stop working
It fell One speaker stop working is not on warranty I want to know if I should open it to check if cables came lose or something .Should I open it.
Open SKy
  • 620 Answers
SOURCE: Z5300e center speaker no longer works
Hi Phineasj
It is possible the speaker is bad, and defective, time to change,or repair, or RMS, try carefully, open and see the cables, you also can welding the cable again the cables IF broke.
good luck
Posted on Nov 26, 2007
  • 185 Answers
SOURCE: z5500 speakers , can it be opened
Hi , And happy new year , You speakers can be opened , but the second you open them, you will lose your warranty , if thats ok with you , then go ahead and unscrew it and get the nut back...if you dont want too lose your warranty , i suggest you leave it in there..
I hope this helped but , Merry Christmas and happy new Year :)
Posted on Jan 01, 2010
  • 32 Answers
SOURCE: Logitech x-230 2.1 Speakers: My speakers power on
If the speakers are still under warranty its best not to open them. You will lose your warranty. If the speakers are still under warranty, take them back to where you bought the speakers and ask them to replace the product.
But to make sure the speakers are working, plugg the green audio jack into another source to see if its the speakers or your pc. helps to narrow down the problem to a single source (pc or speakers), turn the volume up and down to test them completly.
If the speakers work with a ipod or a similar device, it could be your computer that is the problem.
Hope this helped :)
Posted on Jan 04, 2010
  • 3 Answers
SOURCE: Logitech THX Z-2300 only one speaker works
try tapping the speaker box in your palm while the speaker is connected. There might be a bad contact of the wires inside. I had to open up my speaker to find that out. i moved around the wires connected to the cone of the speaker and then started to hear music once i did that. it was the left speaker by the way.
Posted on Mar 09, 2010
bronk50
  • 27725 Answers
SOURCE: Speaker Logitech S-0264B not working with windows xp
if your computer came with a motherboard disc the sound drivers could be on it
if you dont have a motherboard disk you will need to download the sound drivers
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
Posted on Mar 13, 2012
Logitech X-140 Speaker: There is no sound coming from the left speaker after it fell 50 cm. The right speaker works fine, can I fix this or not?
The wire may have stretched and separated inside the insulation so you can't see it. Use a multimeter to test for open wiring.
Jan 22, 2017 | Logitech Audio Players & Recorders
My right speaker has stopped working. Any work around this? by tearing it open?
Unlikely. Check the wiring and the plugs. If they are OK, then you will need to take them apart. The right one is the one that holds all the amplifier parts. The left one is just a speaker.
If you are in the market for new ones, I can recommend Bowers and Wilkins MM1s. They are pricey, but high quality, have a warranty and are repairable. I have been around the factory.
Logitech have support for your speakers here
Logitech Support
Nov 21, 2015 | Logitech Z320 Speaker System
I have logitech Z4 speakers, and my speakers always just stop working, then when they're un plugged and re-plugged in they start to work again. This issue used to happen every couple of days, and
• One possible reason could be a faulty power supply for the amplifier.
• Transformer could be overheating or possibly the main amp itself.
here is a link , should you need to DIY
or just a guide and use it as a reference.
404_118x100.png Computer Speakers
let me know if you need more assistance.
Sep 11, 2012 | Logitech Z4 Computer Speakers
Speaker doesnt work after plugging into wall
ur speaker contains a small transformer in it. i think that transformer should be damaged. changing that will bring ur speaker to working conditions. you are kinda adventurous
Feb 12, 2010 | Audio Players & Recorders
AFTER 3 MONTHS SPEAKERS COSTING OVER $200 ONE SPEAKER DOES NOT WORK ANYMORE
Logitech equipments are usually pretty good. It should be under warranty so I would not try to fix it yourself.
If you bought your product new from an authorised dealer, your expensive speakers would still be under the normal Logitech 2 yeas sound systems warranty: consult your warranty terms an contact both your dealer and Logitech support.
Hope it helps. let me know how you go.
Dec 31, 2009 | Logitech X-530 Computer Speakers
Z5500 speakers , can it be opened
Dec 23, 2009 | Logitech Z-5500 Computer Speakers
Where can I get repair for Logitech Z2300 speaker system? The yellow input to the amp doesn't work - both speakers will work in the other input
Contact Logitech - their information is here:
http://www.logitech.com/index.cfm/support_downloads/support_contactus/&cl=us,en
If it's under warranty, they'll likely be able to replace it.
Dec 11, 2009 | Logitech Z-2300 Computer Speakers
Subwoofer stopped working
After time they may collect dust. clean them a bit.Do u have an extended warranty. may your should use it . if that does work maybe time for an upgrade..
Sep 06, 2009 | Logitech R-20 Computer Speakers
Logitech Z-680
You need a 2 Amp Slow Blow fuse. 250V. Available from eBay
Aug 01, 2007 | Logitech Z-680 Speakers and DVD218 System
Problems with my Speakers
these speakers come with a 2 year manufacturer warranty. a friend of mine had a similar problem and they just sent him a new set of speakers. try contacting Logitech, maybe you'll get lucky too!
Nov 26, 2006 | Logitech Z-5300 Computer Speakers
Logitech PlayGear Amp for PlayStation Portable  Logo
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
