Question about Amana 24 in. ADB2500AW Built-in Dishwasher
Dishwasher Amana ADB2500AW door spring and cable
After renovation in my kitchen (and re-installation of dishwasher) I noticed that dishwasher door falls almost free. I looked at the door spring, and, sure enough, found was not connected. Also, I found a nylon cable on the floor… Now I am puzzled how to connect it all back.
Any support is appreciated.
  • anna moniz Jun 16, 2012
    how many nylon strings do you have? we have the same problem and only see one. Also, do BOTH springs have to be attached, the one on right and left of door?
    Problem Solver:
  • 9 Answers
The nylon cord is part of the door spring mechanism. One end hooks over a tounge at the bottom of the door, then the cord goes around a pully at the bottom, then hooks onto the spring. If the other sides spring is still attached, duplicate it.
Posted on Oct 21, 2009
Why does my dishlex dishwasher DX302 not heat
Dishwashers require a gap for air flow all the way around, not tight fit.
If it works when out but not installed, check the water pipe is not kinked and the door switch is working properly.
Sep 07, 2017 | Dishwashers
Broken door spring on kitchenaid dishwasher
Please read our safety information before attempting any testing or repairs. Before repairing the door springs, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The door opens and closes with the aid of springs. If the springs (or the cables that connect them on some dishwashers) break, the door will drop open hard. The door will also be heavier when closing. If the door drops open, it may also bend the door hinges out of shape resulting in a door that does not close properly and possibly leaks.
When replacing the springs or cables, all of them should be replaced at the same time.
To access the door springs and cables remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to get to the screws over the panel, then close the door to remove the panel.
There are two common types of spring assemblies. One type connects the springs from a hook on the dishwasher cabinet of to a tang on the door hinge .
May 07, 2008 | Dishwashers
Water intake seems less and motor noisy
1- water intake is where water supply line is connected to d/w on bottom left be hind kick plate
2-remove spray arm and upper spray tube at same time turning to the right then you will have to use a torx driver to remove sump Cheers
Dec 10, 2013 | Amana 24 in. ADB2500AW Built-in Dishwasher
Fisher/p nemo dishwasher door
it is sometimes linked to the dishwasher not level or the spring tension on one side getting weak. Refer installation manual http://kitchen.manualsonline.com/mdownloads/c11d2c17-cb0a-489c-99bf-a61513fbf876.pdf to make sure the level is adjusted. May need to replace the door seal in case leak is too excessive.
Apr 27, 2013 | Fisher and Paykel Dishwashers
Dishwasher is not spraying water
check that you aren't blocking the spray arms with items you have loaded into the dishwasher. Make sure that things such as pot handles or silverware is not obstructing the arms
Sep 16, 2010 | Amana 24 in. ADB2500AW Built-in Dishwasher
Dishwasher door spring installation
http://www.partstap.com/ please go to this site for diagram thank you for useing fixya please rate me
Feb 25, 2009 | Dishwashers
Dishwasher making loud noise
Newer washers are designed with a food grinder inside to help grind up large pieces of food. What you are hearing is the grinder doing its job. You do not need to worry about the noise. It should go away after a while as the food particle is ground up.
Jan 10, 2009 | Amana 24 in. ADB2500AW Built-in Dishwasher
Door spring is not connected
look at the other side,it is the same,the cable should go around a pulley then terminate at a flat piece of metal with 4 to 5 slots,(the spring goes here)the slots are to adjust the tension on the door .hope this helps.
Nov 16, 2008 | Amana 24 in. ADB1500AW Built-in Dishwasher
Amana fridge door on wrong side
Generally, doors can be swapped side to side.  Look for some kind of plate where the hinges would be on the other side of the box from where you've got the door mounted now.  It may be covered with a plastic piece.  If you find it, you're in business.  A small socket set is all it usually takes.  Get help holding the door in position as you do the work.  Doors are heavy.
Nov 12, 2008 | Amana ARB2257CSR Bottom Freezer...
Amana 24 in. ADB2500AW Built-in Dishwasher Logo
314 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Mike
Kolbrun...
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
