Question about Polk Audio Audio Players & Recorders
Polkaudio psw202 won't turn on
Trying to fix it myself, found out that the power amp IC was burnt out. The number of that IC is not clear, all I can read is TDA729??. Someone please help me with that number. Thank.
Got the information from Polkaudio customer srevice. IC number is TDA7294.
Posted on Dec 16, 2008
I have found power card of Del In1930f defective, after further checking I have found mosfet A2764 burnt and 1NN801B ic of driving card burnt, please help how to fix this problem.
It is considered unsafe to attempt a repair of a power supply of that design. It will probably cost less, than the parts and expertise, to replace it.
Dec 17, 2016 | Computers & Internet
Bose burned Integrated Circuits
I have the same problem here, this IC is shorted, is made by International Rectifier, it must be a inverter IC the number printed should be a ghost number because I can't find it, maybe BOSE ask IR to put a nonexistent number to block people fix it, the number by the way is P834 HA1M1 here is a photo also, if someone knows about which other number works here let me know please
Aug 13, 2013 | Apple Bose SoundDock Series II Digital...
Philips DCB146 NO SOUND!!
The answer is straightforward. The main power amp has gone. If you are lucky it's a single IC unit which you will find on a big heat sink. It might look like the one shown below.
You will of course need to de-solder it and resolder a new one. The type needed to replace it will be shown by the letters and number on the IC itself.
May 02, 2017 | Audio Players & Recorders
My Philips home theater model hts3105/98 is not working due to IC breakdown hence i need that ic number to replace it. hence please help me.
Every IC has their number printed on the top 1st line. If you have identified the IC, look for the number. If it is burnt & cannot get the number, you will have to refer the schematic diagram of the model. The service manual is available under following url. Just paste the following url in your browser , a download link is there.
http://new.eserviceinfo.com/downloadsm/54246/PHILIPS_HTS3105.html
sonsunny
Jun 17, 2011 | Televison & Video
Polk Audio PSW202 subwoofer. Replaced burnt fuse but blows the next fuse after connecting to amplifier and powering on. What else can I do?
Fuse probably went bad because either the large filer capacitors at the edge of the PCB went bad and or the final output IC mounted on the heatsink(15 pin) fried. Check the capacitors and all the semiconductor components on the board for burn marks or corrosion. You have to remove the heat sink clamp from in front of the output IC to adequately visualize its condition. In fact you might have to remove the large aluminum heatsink attached to the chassis to get a good view of the IC. If it or the heat sink clamp show signs of thermal burns you need to replace it. The IC is a TS TDA7294 mono audio amp available at Mouser Electronics. Replace the 35V 4700mF caps with 50V 4700mF caps. You will only have enough space on the top of the PCB for one of the larger caps. I mounted the other on the circuit side of the board. Note the polarity of the original caps and respect it in their replacements. The fuse is a 5 X 20 medium speed slow blow 250V 2.0A glass fuse.
Aug 17, 2010 | Polk Audio PSW202 Subwoofer
My alpine five channel amp got fried and on checking i found a small eight pin IC burnt in the power supply.how to bypass it?
There is no way to do a bypass without afecting other functions on the AMP. What you can do is try to get the numbers printed on it in order to get a replacement. You may also find it on the diagram but it is a little bit difficult if you do not know how to read it. Next time post the model number for easier reference.
Jan 26, 2010 | Car Audio & Video
843 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
