Question about JVC GR-D290 Mini DV Digital Camcorder
JVC GR-D246E Unit in safeguard mode. Have tried to remove and reattach the battery. Can you help me? Middle of Norway
  • Anonymous Feb 14, 2009
    I have tried, but its not working.disc is not comming out.
5 Suggested Answers
kala
  • 156 Answers
SOURCE: safeguard mode/remove battery & reattach
There should be a error code,what is that?
Posted on Feb 25, 2008
kala
  • 156 Answers
SOURCE: JVC GR-D250 Mini DV Digital... Problem
There is any error code displying on the lcd screen?
Posted on Feb 28, 2008
SOURCE: 01 error code - unit in safeguard mode
I solved the problem! Open the video cassette door. Look closely at the gear mechanism and see if there is any small debris in the gears. If not, using a magnifying glass and a paper clip(must stretch it out and use the tip) gently move each gear(gently). I had my unit ON. Once I moved the gear it became unstuck and ejected Mini DV cassette. I then re-inserted the cassette and it worked. The dreaded SAFEGAURD MODE message was gone and it is as good as new.
Be Blessed
dennis@privatemtglending.com
Posted on Sep 27, 2008
SOURCE: Shows fault E04 remove & reattach battery
Hi, Regarding the above fault with my JVC camcorder, I have solved the problem by removing the tape and replacing with a new one. Thanks anyway.
Regards,
**** Coupe
Posted on Apr 06, 2009
SOURCE: jvc gr-dvx9 E04
The mechanism is out of sync, put a tape in and hold it, it wont go in but will try to open don't let it, remove the battery and reattach, let the tape eject, rinse and repeat 3 or 4 times and it will finally accept the tape.
Posted on Jun 12, 2009
I HAVE A JVC GR-D820EK MINI DV VIDEO CAMERA AND IT IS DISPLAYING UNIT IN SAFEGUARD MODE 06, I HAVE TRIED REMOVING BATTERY AND DC PLUG BUT NOTHING HAPPENS IT WILL NOT WORK ON EITHER PLAY OR RECORD, PLEASE...
i HAVE A JVC GR-D820EK MINI DV AND IT IS DISPLAYING UNIT IN SAFEGUARD MODE 06, I HAVE TRIED REMOVING BATTERY AND DC PLUG BUT NOTHING HAPPENS IT WILL NOT WORK ON EITHER PLAY OR RECORD, PLEASE COULD YOU ADVISE
Feb 11, 2011 | JVC GR-D775, GR-D790, GR-D796, GR-D820EK,...
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Apr 28, 2009 | JVC Video Cameras
Regards,
**** Coupe
Mar 30, 2009 | JVC Video Cameras
Safeguard Mode
What error message appears,it should say E0..
May 27, 2008 | JVC GR-D20EK Camcorder
Problem with jvc gr-sxm58
Do you happen to try with another tape? if so, it needs repair, mostlikely the capstan motor need to change and it needs hinger skill to do this, since you have to adjust it after replacing.
Apr 23, 2008 | JVC GR-SXM58 Camcorder
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
JVC GR-D290 Mini DV Digital Camcorder Logo
291 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
sonic boom...
sonic boom...
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
