Question about Leviton Quickport 5G108 Category 5e Gigamax connector RJ-45 Jack (LEVITON5G108RW5COLORSWHI)
How do you wire the cat 5e multi jack? Which wires go where?
  • 41 Answers
Hi tonybenjamin
Here are the pinouts for a regular fly lead (PC to Switch"hub") and for a cross over cable (PC to PC)
Front view of the RJ45 MALE pin. Pin's top with Locking clip how do you wire the - 02ca060.jpg
1. Fly Lead
Name Pin Wire Color Pin Name TX+ 1 White/Orange 1 TX+ TX- 2 Orange 2 TX- RX+ 3 White/Green 3 RX+ 4 Blue 4 5 White/Blue 5 RX- 6 Green 6 RX- 7 White/Brown 7 8 Brown 8
2. Cross Over
Name Pin Pin Name TX+ 1 3 RX+ TX- 2 6 RX- RX+ 3 1 TX+ RX- 6 2 TX- Extra Pins 4 4 Optionl Pins
(connected straight
to same pins) 5 5 7 7 8 8
Regards
Go-Tech
Posted on Dec 14, 2008
  • Wimpie Hall
    Wimpie Hall Dec 14, 2008
    Hi tonybenjamin
    Sorry about confusion in cable pinouts was suppost to be in a nice table layout.
    1. Fly Lead
    connecter A Connector B
    Pin Wire Color Pin
    1 White/Orange 1
    2 Orange 2
    3 White/Green 3
    4 Blue 4
    5 White/Blue 5
    6 Green 6
    7 White/Brown 7
    8 Brown 8
    2.Cross Over
    Pin Wire Color Pin
    1 White/Orange 3
    2 Orange 6
    3 White/Green 1
    4 Blue 4
    5 White/Blue 5
    6 Green 2
    7 White/Brown 7
    8 Brown 8
    Regards
    Go_Tech
  • 81 Answers
You need to follow this sequence on both connectors (left to right)
1 white/orange
2 orange
3 white/green
4 blue
5 white/blue
6 green
7 white/brown
8 brown
I have been on many sites with Cat 5 systems. What I cannot understand is why are the sockets numbered oddly i.e 1--6 2--7 3--8 etc. Instead of 1--2 3--4 5--6 etc.
Not sure if I understand your question.
Cat 5 (and higher) cables consist of four twisted pairs. The idea is, that disturbances by magnetic fields compensate each other this way. I suppose that the arrangement of the wire on the plugs and jack come from good ols analogue days, where the telephone-call was only on two wires (=one pair). To keep it as undisturbed as possible, the center of the plug (pins 4 and 5 on a rj45) was used. The next pair was spread over them and therefore used pins 3 and 6. Pair three was put on pin 1 and 2, and pai four on pins 7 and 8.
hth, Karl
Jun 17, 2011 | Cat5e Cat.5E Connection Box (512114)
Hello I need to hardwire a tripplite n001-010-bl catse cable to a belkin cat5e keystone jack bel-r6d024-ab5e I do not know the correct wiring configuration to do this. Please advise?
The wiring is done as if you are building your own CAT5e wire. See the following URL: http://www.beginnercode.com/2006/11/09/connecting-network-cable-ends/ . There are other sites. As long as both ends are the same the cable will work (unless you want a crossover connection).
For a PDF version see: http://www.n-tron.com/pdf/cat5ecableschemes.pdf .
I hope this helps.
(Keystone jacks for ethernet come in two types: plug in RJ-45 and punch down the individual wires with the tool. All of the punch down jacks came with a diagram, had the wire arrangement indicated on the unit, and a cheap plastic punch down tool.)
Jan 17, 2011 | Tripp Lite TRIPPLITE N001-010-BL Snagless...
Rewiring a house putting in a net work for the future . what cable cat5e ,cat5e screened , cat6 , cat6 screened . would cat5e screened be better than cat6 unscreened ? cables away from mains ,
I'm guessing when you say screened and unscreened you mean shielded or unshielded. Shielded wire is used when there is a higher possibility of electrical or RF interference. In a typical household those type of interferences are uncommon. As far as the Cat.5e or Cat. 6 decision, Cat 5e is tested to 150 Mhz. compared to a 250 Mhz. rating on Cat. 6 therefore with future speeds in mind I'd go with the Category 6.
Aug 25, 2010 | Dynex 7' Cat 6 Network Cable - Gray
I want basic block diagram of plenum cable
All Cat 5e jacks and patch panels are color coded, making it simple to get the correct wire in the correct position on the jack or etc.
Here is a basic diagram:
Hope this helps!
Aug 14, 2010 | Superior Essex Marathon LAN Cat 5e Bulk...
What wiring to use to connect our RJ45 connectors for computer
The order you give is right. Ethernet uses the orange pair and the green pair (1, 2, 3, 6). Phone uses the blue pair (4, 5).
May 05, 2009 | Computers & Internet
How do I wire up a cat 5e socket to extend my network.
hi, good morning, i'm here to help, the modules should be color coded and the cat 5e will have the same colored wiring when you strip off the jacket, you should use a puch down tool, punch down the 5e wires into the corresponding colors of the module, strip a small portion of the 5e jacket but not the inner pairs of cable, untwist the inner cables and insert and punch down the pairs, the modules should come with some kind of instructions, please let me know if i can be of anymore help
Mar 19, 2009 | Computers & Internet
Data Rack
cat 5e making networking cable setting. Please tell me setting pc to hub and how to networking cable connect the conector.
Jan 26, 2009 | Computers & Internet
Wiring cat 5 jack
If you're doing both ends, it doesn't matter. I tend to use "B" because if the other end is a patch panel, it natively (ie all wires in order) comes as a "B" panel. Less thinking on my part :-)
Carl
Jan 11, 2009 | Leviton Quickport 5G108 Category 5e...
Lan cable Setting for Switch & PC to PC LAN Connection.
If you are asking about connecting two computers together with a hub or switch, plug them into the switch/hub with standard patch cables (cat 5e or cat 6).
If you are asking about connecting two computers together directly using a LAN cable, then you will need a "Crossover" cable (cat 5e) wired specially (oranges transposed at one end for the common -B pattern) for direct LAN connection.
Jan 01, 2009 | Computers & Internet
How to wire up a cat5e faceplate with cat 5e wire
If you want to learn how to wire cat5e, here is a video:
http://www.serverracksandcable.com/cat5-cat5E-cat6-cat6A-cables-limitations.php
Mar 07, 2008 | Computers & Internet
Computers & Internet Logo
422 people viewed this question
Top Leviton Computers & Internet Experts
ashburton
Michael Galve
Michael Galve
Are you a Leviton Computer and Internet Expert? Answer questions, earn points and help others
