Question about Palm Treo 755p Smartphone
Phone does not ring enough before I can answer
How do you increase the amount of rings. Or is it the factory default only?
Any advice?
  • Anonymous Feb 20, 2009
    I needed to increase the rings once before, all you need to do is call up your carrier, and ask them to do it.
    yarely
I have had this problem for years, and have Sprint. I have called them and complained of this problem, and was advised that there was nothing that could be done about it.
Posted on Jul 21, 2010
    Problem Solver:
  • 19 Answers
Best Regards,
Sam
Was this information helpful? Please rate it!
Posted on Dec 14, 2008
My phone only rings 5 times before the answer function takes over. Is it possible to increase the number of rings?
The number of rings before your answring message picks up the call is controlled by your cellphone service provider. call in to your voice mail and then follow the instructions about going to options and setting. There should be a setting in there for the amount of rings to wait before answering the phone.
Feb 04, 2015 | Cell Phones
How to extend ring tone on I phone 4?
Contact your carrier's customer service. Ask them to set the maximum time before shunting the call to voicemail. They deal in time rether than number of rings. On my AT&T iPhone, the default was 20 seconds and they increased it to their maximum of 30 seconds.
Jul 09, 2014 | Apple Iphone 4s I Phone 4 S Factory...
Increase number of rings before voicemail, vtechcs6419
The CS6419 isn't an answering machine. The phone will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on an answering machine or voicemail system, refer to the documentation for that system. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jan 28, 2014 | Vtech DECT 6.0 Digital Cordless Phone
My phone doesn't ring long enough to enable me to answer
hi , increase volume in the [ringing ]mode . or maybe your speaker is goin
Sep 29, 2013 | Samsung J700 Cellular Phone
How do i increase the length of ring time before it goes to answer machine?
Step 1: Determine the make and model of your phone/answering machine.
Step 2: Repost your question, being sure to include the information from Step 1.
Nov 10, 2011 | Lands Phones
Nokia 1650 Type: RM305 phone not ring then ringtone click restart problem
Nokia 1650 Type: RM305 phone not ring then ringtone click restart problem. Hi bathtubs/whirlpool try to my advice just go to Setting and select to Factory Reset and default password 12345.its back to normal setting.
Jul 23, 2011 | Home
Answer phone responds too soon
The usual numbers of rings before the machine answers is 2 or 4. If that is not enough, you are out of luck. If it's 2 now and you want 4, there should be a menu button you can press, and when you hear "number of rings" use the up/down arrows to increase the number. Then press the "set" button. Hope that helps.
Mar 05, 2010 | Uniden Cordless Phone
I want the fax to work with an identa ring. How do I program this? As it is now I have to turn on the fax to receive. Does this HP work with identa ring?
The following set up assumes you have one conventional phone line, but two different phone numbers. One being your regular phone number and the other a distinctive ring for your fax machine
If that is what you have then this is how you set up the phone. Its important to know what type of distinctive ring your phone company will send to your phone. If it doesn't work you can talk to them about getting a different one than their default distinctive ring.
2 Set the HP all-in-one to answer incoming calls automatically.
Press the Auto Answer button until the light is on.
3 Change the Answer Ring Pattern setting to the pattern that has been assigned to your fax number by the telephone company, for example, double rings or triple rings.
For information on changing this setting, see Change the answer ring pattern
(distinctive ringing).
Note Your HP all-in-one is factory-set to answer all ring patterns. If you do not set the correct ring pattern assigned to your fax number by the telephone company, your HP all-in-one might answer both voice calls and fax calls or it might not answer at all.
4 (Optional) Change the Rings to Answer setting to one ring or two rings.
For information on changing this setting, see Set the number of rings before answering.
5 Run a fax test. For information, see Test your fax setup.
Your HP all-in-one will automatically answer incoming calls that have the ring pattern you selected (Answer Ring Pattern setting) after the number of rings you selected (Rings to Answer setting). Then it will begin emitting fax reception tones to the sending
fax machine and receive the fax.
If it is easier or you want to know other options which may be more applicable to your phone setup. You can find that information here.
http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
Jul 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Increase the number of rings
the default setting is 5 rings. if you need to change that:
set the ring to answer to higher number, however, that will put the machine in manual answering of fax.
the better setting is to rest the phone or the answer machine to a lower number of rings.
Jan 13, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Cannot recieve faxes
I just spoke with customer service live chat.
-press the "Fax Mode" button
-press the menu button
-The Fax menu screen will be displayed
-press down arrow button 5 times until the screen displays "Ringing and Answering."
-press the select button
-the display will show the "Ringing and Answering menu
-press down arrow button 4 times untip "Pick-up On?" is highlighted
-press the right arrow button 2 times until the screen displays "1st ring"
-press the "select" button and now "1st ring" will be set as the default.
Apr 01, 2007 | Lexmark X8350 Print, Scan, Copy and Fax...
Palm Treo 755p Smartphone Logo
83 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
