Question about Sharp AL 1631 Copier
Scanner Bar won't move
Made a noise befor it quit
  • Anonymous Dec 16, 2008
    scanner bar wont move
  • Sharp Master
  • 19,396 Answers
Try first unplugging the power cables for ten minutes, also restart the computer.
Check if this model has a lock button to secure the scan, this is usually indicated with a lockpad, and is a small tab, if there is one is indicated on the manual.
Plug it back and do the following:
This sounds like an hardware fault, since the scanner starts, but just in case , ensure the drivers are working fine by reinstalling software from scanner disk. And eventually test the scanner on a different computer, for example a laptop. Use the scanner CD to do intall scanner drivers before connecting the scanner.
If it still does not work.
Check if the scanner lamp goes on when you send a scan, if not the lamp must be replaced.
The most likely is that the traction belt had slipped out, one of the mechanichs are stuck, or the motor is faulty.
In this case the scanner must be taken apart, the job can be done at any local repair shop.
Posted on Dec 14, 2008
My Canon MG8120 all-in-one makes a loud noise when copying (not when printing). How do I fix it?
Dear
from the question I understand, the scanner move to right and during return it starts noise.
The problem with scanner assembly, It might be dust accumulated on gears, the scanner belt might have loose or the grips of the belt has worn out. Proper cleaning and lubricating the moving parts may overcome also if the belt worn out it has to be replaced.
In case of at home position it gives noise then the home position sensor may dirty/dusty, it has to be cleaned.
thanks.
Feb 15, 2015 | Canon Pixma MG8120 Wireless Photo...
Tip
How do I troubleshoot a Symbol Barcode Scanner?
<p>Barcode Scanners Symbol read and translates the barcodes on merchandise. The scanner translates the bar code symbols on the label says the price of the item and merchandising information. Traders use the symbol bar code scanner to identify their merchandise. A programming error in reader bar code symbol will cause confusion and may lead to loss of money. Troubleshooting barcode scanner symbol allows you to identify bugs and find solutions to errors. <br /> <p><br /> <p>1. Remove the installed fonts from the reader bar code symbol. The sources of such capacity to disrupt the functioning of your bar code scanner. Press the "Menu" button on the scanner bed and press the "Select" option when the source is highlighted. Press the Delete button to remove the sources of the sample. <br /> <p><br /> <p>2. Close the bar code scanner Symbol with a source of energy. The scanner has a power cord can plug into an outlet. If the scanner runs on batteries, the battery is fully charged before using the scanner. <br /> <p><br /> <p>3. Move the scanner closer to the bar. The symbol bar code scanner cannot calibrate the bar if you wrong position. Place the scanner directly over the bar and wait for the scanner to read and transmit the code. <br /> <p><br /> <p>4. Wait until the bar code scanner symbol to complete the boot. The symbol bar code scanner is initialized when the USB cable is connected to the computer. Initialization requires a short period of time to complete the process. Let the bar code scanner symbol to be idle for 4-5 seconds before you first scan an object. <br />
on Jun 26, 2011 | Computers & Internet
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Mar 31, 2014 | Brother MFC Office Equipment & Supplies
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
Scanner won't scan. the light is on but the scanner part won't move. makes a lot of noise. the belt is not brokern
depending on the scanner the belt may not be broken, however the gear that it rides on may not be moving, or the belt is slipping. Some scanners the glass can be removed for you to visially see the gear and evaluate from there
Jul 15, 2011 | Office Equipment & Supplies
HP C7180 All-In-One (Fax)
Does it say Scanner Failure...?
If then try these steps mentioned bellow:
Remove all the ink cartridges from the All-In-One.
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is above the place wher we install ink cartridges it is a metal part which moves in a metal bar) Too and Fro till you feel the carriage is moving smoothly.
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector.
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Then if it prompts the ink cartridges insert ink cartidges
Now try printing a test page or make a copy
If it still makes a loud noise and the message comes up as scanner failure, then either the scanner or the scanner machanisum is bad, you may have to replace the unit
Good Luck
Sep 01, 2008 | HP Photosmart C7180 All-In-One InkJet...
Scanner making clicking noise
I just got that scanner back, L1 error code on a Sharp copier. Means the scanner can't move quick enough to satisfy the specs.. Removed the lock, not needed. Oiled the bar, scanner works ok now. Will look for Triflon lubricant, my favorite. Will check with local repair shop for recommended lubes. That light sensor switch is not necessarily on your unit, but I see them on a lot of machines. Sometimes it's just a little tab or button, hard to find. Check the freedom of your scanner bar. Temporarily loosen the drive if you can. The bar must move freely.
Jul 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
CanoScan 5000F - Scanner bar is stuck
hi all;
i fixed it by taking the thing apart, pushing the scanner head (the block that is stuck-- that normally moves) back to the starting position. Make sure its snug at the end, a little bit off and you'll be putting it have to take it apart and back together a second time. There's a mirco swtich in there somewhere, and you need to make sure its pressed...
reconstruct, and hey presto, a working scanner! this also worked for my epson 1250 that got stuck once.
Easy as a section of gateaux.
Oct 04, 2007 | Canon CanoScan D660U Flatbed Scanner
Makes grinding noises, refuses to scan; WinXP
take a look on the underside of the scanner. there may be a switch that goes from lock to unlock. try to move it to lock and back into unlock. this lock is usually used to lock the bar from moving during shipping. if this got moved back to lock or bumped while you had it turned over, the scanner will not allow the bar to move.. try this first.
Aug 16, 2007 | HP ScanJet 6200C Flatbed Scanner
Sharp AL 1631 Copier Logo
179 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
