Question about Sony KP-46S25 TV
I have a sony 51 " rptv. the on screen image arcs on top and bottom towards the middle of the screen he sel diagnostics showed 1 timw akb and 1 hv. the timer blight has been blinking 4 times then stops any help out there?
  • 2 more comments
  • olson_brian_ Dec 14, 2008
    kp-51ws500
  • olson_brian_ Dec 15, 2008
    So what exactly am i looking for? Is this something the amatuer should not attempt? What would it hypothetically cost to repair?
  • fareedy2k Mar 09, 2009
    Is IC8003 soldered, or is it socketed? Can I replace it easily?
    Thanks!
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Please mention exact model number of Sony RPTV.
  • 10,594 Answers
Ok,
4 times blink is error code for Vertical Deflection problem and you need to check +15 and -15 volt supplies on D board and IC8003 is suspected.
Needless to say, check above in case you have enough knowledge and experience of big TV repair as high voltage shock risk is involved.
Thank you.
Posted on Dec 15, 2008
    Shahid Electronics Dec 15, 2008
    If you have no experience of TV repair then TV tech is best choice to fix this and ask an estimate.
SONY kp-51ws510 rear projection tv. recently it started showing a rainbow on the left top corner and middle bottom of the screen. what might be the problem? can it be fixed? for how much?
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2010 | Sony KP-51WS510 51" Rear Projection...
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Control of vertical TV image projected on the screen
You can try looking for 2 things
1. A button on your remote that says either: ARC, Ratio, 16:9, 4:3.... Some remotes have a picture of a square with arrows pointing out towards each corner..... I'm unfamiliar with this set, but it sounds like a widescreen, so give it a go
Apr 22, 2009 | Televison & Video
Kines on Screen and Fading
Open up the front of the set by removing the speaker screen and the black piece of particle board. on the bottom right you will see 4 knobs. Turn those knobs slowly till the arcs go away. The 3 knobs on the bottom are for color. the 3 on top are for the focus.
Jun 30, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP51W40 Blue tube flashes
I do not think the old tube rejuvenator will do much if the HV is arcing. The CRT it might leaking some coolant or some moisture from it is causing the arcing.
I would suggest to read the info from this website to re-seal it or replace the coolant.
Let me know if you need further assistance.
Apr 21, 2008 | Sony KP-51HW40 51" Rear Projection...
Great Sound...no picture
v1 is your verticl scan has stoped for a reason,akb 1 is the feed back from the crt to the video ic, hv 1 is high voltage stop the set ,clear the error codes and start again record them and conpare the results for the true fault.
Sep 12, 2007 | Sony KP-51HW40 51" Rear Projection...
Blue Screen and TV shuts off
Yes, you are correct on the phrasing. The CRT's were a common issue with these units and all three must be replaced as sooner or later the green will follow the other two CRT's. It was a great model and had a beautiful picture when operating normally. The CRT's are costing about 200 each for rebuild as the green and blue are mostly no longer available. Your repair cost are going to approach $1000.00 or more.
Mar 07, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
128 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
