Question about RCA HD52W59 HDTV Projection Television
RCA HD52W59 Sunny, Thanks for getting back to me. I asked a guy from fixya about m problem and he told me to remove the back of the tv to get to the mirrors and lenses/bulbs. The back panel only revealed the electronics of the tv. I removed the front where the volume/channel/power switch is to gain acess to the bulbs/mirrors. I cleaned the bulbs which were dusty but seemed to all be on. What bulb did you replace and where was it/how did you get to it? Is there a separate bulb than the green/blue/red bulbs?? Thanks for your help. By the way...my tv is still blurry and still has weird tinting to it. Troy
Actually, we didn't remove any bulbs, we removed the lamp in the back of the tv.
Posted on Dec 14, 2008
I have an RCA HD52W59 TV that will turn on and picture is fine for awhile, then it will fade to total black. Still has sound and does not power off. Nothing will show on screen, not even menu options....
Thats a deflection problem which is causing the CRTs to shut down during deflection loss. The deflection board will need replacement. You can get replacement deflection boards from www.tvrepairworld.com
Apr 23, 2011 | RCA HD52W59 HDTV Projection Television
My rca hd52w59 tv looks like its in 3-d. auto covegnence used to solve the problem most of the time but now it does nothing. pic is constantly looks like 3-d now. the colors r all not right. i get it close...
Hi
Thanks for using FixYa. You’ll need to change the convergence chips which are located behind the black heat sink; you can see once you open the back off the TV. You can buy the convergence chips from this link; also if you want you can buy repair kit which comes with complete installation and parts. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | RCA HD52W59 HDTV Projection Television
No picture but has sound
Coil L14401 is not making a good ground. Remove him carefully, scrape the ends clean and the board where he was removed. Now reinsert and resolder this little guy,and Bingo you have your TV back. This is a common problem with your TV! Thanks for asking!
Jan 30, 2010 | RCA F27442 27" TV
HD52W59
High, if you select parental controls from your main menu, it will ask you for your password.
Once that screen is up press the VOL+ and CH+ buttons on the front of your TV at the same time for at least 8 seconds. Once you've held them long enough you should see a message pop up on the screen saying that parental controls have been unlock and you will be able to set a new password or back out of the menu and use the TV unrestricted.
Note: Don't do this while the kids are in the room, they learn quick!
Hope this helps FixYa,
Chris
Apr 30, 2009 | RCA HD52W59 HDTV Projection Television
RCA HDTV Model # HD52W59
I hope it is still under warranty,cause you need to either fix the problem with a A/V repair guy or return it and get your money back.
Don't fool around with it.
solutiondoct
Nov 06, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD TV
i also have this problem rca SUCKS i had a tech look at and the power board is shot same problem as you easy fix right NOT rca changed the boards to a upgrade now i have to search for one mine is 1 year old hope this helps my guy said adout 300. if he can get the board i called rca and talked to them i ask what happens to the tv in 1 year again cause its the same board no upgrade JUNK i let you know if i get one OH YEAH RCAS ****
Jul 10, 2008 | RCA HD52W59 HDTV Projection Television
Conversation
The service # is hd52w59 and then something like yx1 or etc..... On the model # tag, this is written in very small writing. There is no way to remove the convergence option. Go to menu the set up and there you should find convergence. Choose convergence and run auto converge. If this does not work then there is a failure on the convergence power supply, convergence amp, or the deflection/power bd.
Mar 19, 2008 | RCA HD52W59 HDTV Projection Television
Getting channels set with out the remote
If the tv does not have the menu option you will have to get a unaversel remote
Mar 06, 2008 | RCA HD52W59 HDTV Projection Television
HD52W59 bowed picture
Check your screen. I have the same problem with mine. If the screen has a ripple in it, it could give the same effect.
Dec 15, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
180 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
