Question about Coleman Powermate Premium Plus 6250W Portable Generator
Starts fine but no AC
Hello Carl,
I am located in the NE New England and we were just hit with an ice storm. I am trying to help some people by providing some power via my generator. The Coleman Powermate 6250 (B/S engine) starts fine but no AC. I read your article and I beleive it needs to be flashed. I has been idle for 1year or more. Before I try all the electrical measurements I would like to try the flash method. ANy quick response would be great.
  • 169 Answers
Hi Steve,
Sorry to take so long to respond, I didn't get the email telling me to look here.
Because you're in a dire situation I'll give the quick and dirty but very dangerous way to flash any generator. You're gonna want a friend to at least watch and shut the generator off if you get into trouble.
Make a pigtail from an unused 110v electrical cord, pretty much any cord will do but you want one that is easy to hang on to. You want about 1/2 inch or maybe less of bare wire at the ends of the white and black leads of the cord. Plug this into any of the power outlets on the generator.
Start the generator and let it come up to speed.
Using a 9v dry cell or a 6v lantern battery, tap the bare wires of the pigtail onto the battery terminals. Polarity won't matter. You want ot be very careful doing this because if it works you'll suddenly be hanging on to a 110vac live wire. You only need a very short burst of electricity into the power windings to get the rotors magnetic field going.
Once you've done the slap above remove the pigtail and plug in a light or some other small load for 5 minutes or so. We just want to make the rotor coil work for a bit to "recharge" the residual magnetism in the rotor.
Please be very, very careful - in the shop we only do this if there is no other way to get it done, and we work as a team with the spotter having his/her hand on the engine kill switch.
Posted on Dec 17, 2008
Ge Gsh25jsxnss side x side fridge is not getting cold, took plate off & damper works fine, I don't see ne kind of fan, it goes straight 2 the freezer near the ice maker. freezer is cold & working fine
Evaporator fan motor has probably failed. p/n WR60X10185
It is located in the freezer section, behind the back panels inside, and under the icemaker. Remove the screws on the bottom panel in the freezer, remove the ice maker, auger motor, and panel. is is about center of the freezer.
Jun 22, 2016 | GE Refrigerators
How do i get my WR 100 to stop squeaking durring a weather emergency?
Have you tried tuning to different NOAH frequencies to see if one of them gets better reception? Also, if the radio is close to other electrical devices, they could be causing interference with your weather radio reception.
Just a couple ideas tossed out there.
Good luck.
May 10, 2012 | Midland WR-100 Weather/RDS Radio
My 1993 geo storm starts and idles fine but as soon as i touch the gas or try to drive it putts and stalls..does not want to go
Sounds like a fuel filter is clogged or a very weak fuel pump. Filter can be picked up at local auto parts store. Located underneath the car on the inside of the driver side frame rail usually.
Jul 14, 2010 | 1993 Geo Storm
Water doens't drain properly and sitting there,
that's fairly common for window units, it's ok to drill a small hole in the underside of the case to drain the water, just be sure you don't puncture the condenser in the process.
Aug 18, 2009 | Frigidaire Heating & Cooling
Front blwer stopped functioning after an ice storm
The same thing happened to me. I replaced the blower resistor, and everything is back to normal. This is something that is easy to replace it is located behind the glovebox. There is two elec. connections and two screws to remove. Put in the new one and your done. You do have to purchace the part at the dealer though. I think I payed about $25.
Hope this helps
Jan 09, 2009 | 2005 Chrysler Town & Country
6250 Gen that starts but no AC
He gives a good way to troubleshoot many of the Powermates. He's slightly wrong on 2 points:
1) Not all powermates have brushes, the smaller ones are brushless.
2) You don't really need 12 volts to flash, I prefer the 9v dry cell because it can't provide so much power that it fries your rotor (a car battery could).
Note that his method is much safer than what I described and you ought to do it that way if you can.
Dec 17, 2008 | Coleman Powermate Premium Plus 6250W...
Unusable new oven after ice storm
HI. the storm has caused an electrical surge that traveled through the home wiring system and, the Oven control received the hit in this case. it is damaged at this point, and it should be replaced asap, if possible. this code represents a major control breakdown. the board is ruined.
replace it asap.
Dec 17, 2008 | Whirlpool RF380LXPS Electric Kitchen Range
Not hitting rev limit
Hello there matey...I'v got a gti 8v anniversary! seems to have the same problem the day i brought it...some GTi's just do that...i have heard its got to do with the ECU..bringing fuel to the engine..they way i overcome the lag of a 8v was getting a Pipercross Viper induction kit!..I dunno if ur 4om england or america!? in england they retail for about £250.00!...but wooow! they make a different! the engine gets so much cold hair that it seems the pin is going to fly of! it flys past 5100 revs..and theres no lag!.. feels better than a 16v..also think of a ecotek valve made a alot of different even tho its used 2 M.P.G...
Good luck...
Godfather ;)
Jun 27, 2008 | 1996 Volkswagen GTI
Region Problem
As on english game it is PAL but others are diffrent so i am afraid you will need to buy japaneze games. Hope this helps...
Jan 26, 2008 | Nintendo Wii Console
Coleman Powermate Premium Plus 6250W Portable Generator Logo
861 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
