Question about Wolf Range WKGD-1 Gas Single Oven
Digital panel says ''checksum''
Wolf 36'' built in oven. Had a power failure (oven was not on). When power was restored, oven continually beeps and reads ''checksum'' on panel. Only way to stop beeping is to have circuit breaker off. Cannot use oven. How do I fix this? Need to use oven for holidays!!! Help!!!
  • Anonymous Mar 05, 2009
    Same problem here
    hope i find the solution or i be dammed if the a power outtage caused this, and would hate to have to replace the PC board.
    James
  • Anonymous May 04, 2009
    any luck?
2 Suggested Answers
SOURCE: Wolf Double Oven
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Posted on May 22, 2009
  • 1015 Answers
SOURCE: Wolf wall oven error message: RTD Open
RTD is resistence tempature detector. The oven is telling you that the tempature probe circuit is open. The temapture probe may have been damaged due to the self-cleaning cycle or it could just be the wiring harness is loose. You will need to remove the tempature probe and test it with a ohm meter. The average reading should be aroun 1200 ohms at room tempature. If it is testing open or the ohm reading is way off then you will need to replace the tempature probe. If it is testing good then it could be aproblem with the control board.
Posted on Dec 19, 2009
Fisher double oven OD302. Periodically it will start beeping, shut off with no default code
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 09, 2017 | Fisher Ovens
My Miele oven has a constant alarm going off every time I try to turn it on, it won't let me set the temperature
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Nov 30, 2016 | Miele Ovens
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
Apr 21, 2014 | Whirlpool Ovens
What causes the beeping sound coming from my Hearthstone propane stove? I bought my Hearthstone propane stove secondhand.
Oven keeps beeping:
Read more :
Jan 19, 2014 | Thermador Ovens
F3e2 error
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
After a power outage / low current power problem this evening, my whirlpool range, Model # SF315PEKW0 started beeping annoyingly, and displayed the following code F1 E1. Also, after, the oven would not...
The "F1-E1" fault code signifies an EEPROM checksum failure within the electronic oven control. Disconnect power to the range for longer than 30 seconds. Re-apply power and observe the display for longer than a minute. If the failure remains, disconnect power and replace the electronic oven control board.
Jul 24, 2011 | Ovens
I have a 36'' Wolf LP oven with 4 burners and a charbroiler in the center, When lighting the charbroiler, the electronic igniter continues clicking up to 5 minutes after the charbroiler lights
Hi.
The igniters are all controlled by a main hub switch located under the cooktop panel.
Replace the sparking igniters module to fix the sticky igniters problem.
Regards.
Ginko.
Mar 03, 2010 | Stoves Ovens
Whirlpool electric double oven #RBD305PDQ14 control panel blank
I suspect a poor connection at the wiring to the EOC is the cause of the failures.
Apr 21, 2017 | Whirlpool RBD305PD Electric Double Oven
Beeping sound and f8 displayed
F8 means to replace the elctronice range control board. Evidently the power failure caused damage to the board.
May 24, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Wolf Range WKGD-1 Gas Single Oven Logo
105 people viewed this question
Top Wolf Range Ovens Experts
John Rodgers
John Rodgers
Fred Sops
Lakeland Appliance...
Are you a Wolf Range Oven Expert? Answer questions, earn points and help others
