Question about Motorola Mobility RAZR V3
White Screen so my razr's screen went white....i can see some of the letters and it works fine..can anyone help me???
  • Albert001 Dec 15, 2008
    Same problem key a key screen turns white?
    Brigadier General:
  • 7,752 Answers
You need to take the phone and have the LCD replaced on teh phone
Albert001 - change the lcd or flexcable
Posted on Dec 26, 2008
V3c RAZR white screen at shut off only
can you do formatting? format it now, their is some program have deleted in your phone. i can format a cellphone, but in nokia. maybe i will find a way to solve your very little problem. i have a problem too! can you solve it? my problem is your phone.
Mar 13, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Motorola RAzr V3 - screen went black but key pads lights up
replaced the flexcable on the phone to have it fix
Jun 29, 2008 | Motorola Mobility RAZR V3
Motorola razr v3 (black) screen has white blank
Well i suggest that you take the case of your phone and have a look at your screen maybe some of the screws have gone missing or the screen has just worn itself out? . Note youll need a t6 or t7 torx screwdriver to do this , hope i helped
Oct 17, 2007 | Motorola Mobility RAZR V3
White screen`
the white and black screen issue on the Razr V3xx can be a bad LCD. If the LCD is good then the issue is on the main board. The most common failure is broken contacts on FL6505 and FL6504. resoldering might hold up for a while but replacement is the best option.
the side view clearly shows the damage to the filter. this is only visible after the solder is removed.
hope this helps.
Oct 07, 2007 | Motorola Mobility RAZR V3
White screen on Motorola RAZR
I use to work for Cingular Wireless and this happened often. Try opening and closing the handset a little forcefully. It should re-seat the screen onto the contacts. If that doesnt help, have it replaced since its new. Best of Luck.
Sep 05, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Screen went white
Have you tried removing & re-inserting battery and power back on the phone?
Sep 04, 2007 | Motorola Mobility RAZR V3
White screen
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything
Sep 03, 2007 | Motorola Mobility RAZR V3
Blank screen
Aug 27, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Screen
Can you see water inside the LCD? if you can have a professional clean it out for you. If not, try replacing your battery because if it somehow got wet too then water does more damage to the battery than the rest of the phone. if it's still not working reply here and I'll help further
May 22, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
29 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
