Question about Estate TAWS800JQ Top Load Washer
Spin problems washer will not spin the clothes, they are still real wet when done
  • Estate Master
  • 8,220 Answers
spin problems - f11cf48.jpgYour coupling has broken most likely. Here are some pics and directions amigo: WISDOM
Posted on Mar 03, 2009
Our Kenmore Washer 110.22722101 spins but does not have pressure so clothes are still real wet. What would cause this issue? It spins but does not have power.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 13, 2011 | Washing Machines
Clothes are soaking wet after washer is done
maybe your clutch is slipping not getting full spin speed,,,,or could be a problem with your basket drive assy
Feb 21, 2010 | Whirlpool LSB6200KQ Top Load Washer
Clothes soaking wet after washer is done
There is either a problem with the drain or spin cycle. Before the spin cycly starts, ensure that the water drains fully. If it does, then it may either be the belt slipping or the timer malfunctioning. If there is water in the tub when it starts spinning, then you have a blockage in the drain line.
Feb 11, 2010 | Whirlpool Washing Machines
I have had my Kenmore 600 dryer serviced twice. Today, a thermostat was replaced. The timer doesn't advance, the clothes won't dry and water is leaking from the duct. Is there a problem with this model?
I don't see a lot of complaints from this model. There can be some moister
from the dryer, but not water coming out of the duct, clean the rear duct of the dryer to the outside vent to make sure you have full air flow and so you don't cause a fire if it is full of lint. Then check your washer, are the clothes real wet after the cycle is done, they should not be that wet after they spin,
if it was me I would spin them twice or see if there is a option to spin longer if they seem wet.
Feb 04, 2010 | Kenmore 62602 Electric Dryer
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Aug 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Jul 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Soaking wet clothes
Burly Bob,
Is this the same model as listed by the previous poster? If so, does the washer ATTEMPT to go into the spin cycle? That is, does the timer advance to spin cycle properly, and can you hear the transmission or drive motor engage?
May 31, 2008 | Kenmore 22422 Top Load Washer
Estate TAWS800JQ Top Load Washer Logo
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
