Question about Gateway MX6124 Notebook
I can't maximize the screen to the largest size
The screen won't maximize to the largest size
  • Greg Skelton May 11, 2010
    Is the a TV, a laptop or desktop you're asking about? What make and model? What is the current display size and what size do you want it to be?
    This is like taking your car to a mechanic and saying the car isn't working right and walking away. In order to fix the problem you need to be specific.
Maximize button wont let me make screen bigger
That's not what maximize does. It merely enlarges the current window to full screen size.
Aug 25, 2013 | Computers & Internet
Tip
How to set Internet Explorer 8 to open in maximized window always?
I saw most of the people were asking for the option to maximize all Internet explorer windows size. There are some tricks which might work only for some windows but not for all the Internet Explorer windows. As I am working as a technical support, I found an option to set all Internet Explorer Windows maximized.
I will provide you the steps to set this potion, please try this and let me know if this worked for you.
1. Open Internet Explorer and press F12 to open Developers tools windows for Internet explorer.
2. Click on Tools and select Resize.
3. Select the maximum screen resolution size you have.
4. Close the Internet explorer and reopen it to get the maximized windows.
From now you will be able to open any Internet explorer windows in maximized size even though if you open a link right clicking on it and select "Open in a new window".
Ref: http://www.techiesspot.com/index.php/topic,312.0.html
on Mar 17, 2010 | Computers & Internet
I have just installed the above product. I am running a widescreen external monitor off my lenovo laptop. The issue is that the size of the app is about 1/2 the full screen size....when I max the screen...
That needs code changes. the program was set to have maximum maximized-window-state size that cant exceed the size you have maximized it to. So, it can't be made more than that unless through the codes by the developer.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 17, 2011 | MyVirtualHome
Opening new window, window is reduced in size. Any tricks?
Generally, it opens up the same size it is closed. Try opening it up...either webpage or document...maximize it to fit the screen...go to file>exit or close....don't use the X at the top of the screen. The next time you open it, it should be maximized. Try it out! I know it works with webpages.
-rate if this post helps :)
-best of luck
Oct 20, 2010 | Acer Computers & Internet
My screen is so small cant see anything?
If you mean the size of the webpage content then go to that particular webpage and hold CTRL key in the keyboard and scroll down the mouse.
If you mean the size of the browser then you have to maximize it by simply hitting the maximize button in the upper left corner of the browser.
If you mean the size of the main screen then refer to the screen buttons that usually situated in the bottom part of the screen.
Sep 01, 2010 | Facebook Social Network
Screen is only 75% of the normal size.I think this is hardware problem.
It's probably the device-drivers for your video-card
(the wrong driver won't "maximize" the screen)
or it could be just the "settings" for the current device-driver
(wrong "resolution" causes the wallpaper to not be maximized).
Aug 02, 2010 | Acer Aspire 1410-8414 Netbook
Screen Can't Maximize
Go under setup by pressing [F2] when you boot up. Go to Advanced, then go to Video Expansion Mode-and select Enabled. Then save and exit.
Bob bob@i4UT.com
Dec 27, 2008 | KDS Valiant 6480iPTD Notebook
Alienware glitches
if your useing vista turn off window transparency.
Apr 15, 2008 | Computers & Internet
Maximize Screen Display
hello
TRY THE FOLLOWING,
GO TO CONTROLPANEL
CLICK DISPLAY PROPERTIES -> CLICK ON SETTINGS TAB
CLICK ADVANCED -> IN THE GENERAL TAB CHECK FOR THE SCREEN RESOLUTION 96 DPI IF IT IS SO THEN GO TO MONITOR TAB
JUST MAXIMIZE YOUR SCREEN REFRESH RATE.
Mar 21, 2008 | Computers & Internet
Gateway MX6124 Notebook Logo
71 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
