Question about HP Media Center M370N (DM163A#ABA) PC Desktop
Ned to replace cpu fan.
My cpu is hp model 772n (P8566a). How do I get to the part with the least amount of taking apart?
    Problem Solver:
  • 4 Answers
I think that particular model has the fan mounted in the back of the case just below the power supply. It has a duct that goes from the fan to the processsor. Remove case cover and remove the duct by pressing the 2 tabs on the top of the duct and rolling it back and out. Unplug the fan cable from the mainboard . Make sure you remember the connector as you will have to plug the new fan cable back in. Remove the screws that hold the fan to the case and remove the old fan. Install the new fan, plug in the cable and if your computer is dusty on the inside blow it out with some canned air . Re-install duct by sliding tab at bottom in first then pull up to lock in top tabs. Replace case cover and she's done.
Posted on Dec 14, 2008
Cpu fan broken
See utube for video on disassembling your computer. Search for your model and then your issue; "hp m7 disassembly" will show how to disassemble an M7.
Dec 03, 2013 | HP Computers & Internet
Fan is broken at center where magnets are
Replace the fan. You can find them very cheap on ebay. You just have to take the laptop apart to install it. While you're at it and have the laptop apart you might as well put a fresh coat of Thermal Paste around the CPU and Heatsink. I'm sure it's thin or dried up by now since the fan was faulty.
look on ebay and in the search box type your computer's make and model followed by the word fan. For example. HP Pavilion DV1000 Fan
http://www.ebay.com
May 16, 2012 | Computers & Internet
"CPU fan stopped working" message,
You can order a replacement fan from HP. Search for replace parts under your model computer when you go to HP's web site.
Aug 09, 2011 | HP Pavilion p6370t PC with Intel R Core TM...
HP rp5000 desktop keeps shutting off
You need to open the case and watch the CPU fan. If the fan is not spinning or is spinning slowly it will need to be replaced. Take the computer into your local computer repair shop so they know which processor fan you have for a suitable replacement.
You may notice a large amount of dirt and dust build-up around the heat sink and fan. You can either buy a can of compressed air and give it a blast or take it to your local garage and use an air hose or tyre inflater to blast the dirt and dust from the entire case.
Jul 24, 2011 | HP rp5000 PC Desktop
Can I replace the CPU fan on my Gateway 2625
Yes you can as long as you know how to take it apart. There are no user access compartments like the RAMs, to remove it without taking the whole thing apart.
Oct 28, 2010 | Gateway (8005615) CPU Heatsink & Fan
HI I need the plastic frame which surrounds the processor and is under the cooling fan assembly on HP Pavilion a1540n. The fan and it's cooling fins are attached to the frame with two levers/clips. How can...
Well we done this couple times on our own machines;If you broken the Face/Plate where your Cpu set in place,1.you maybe able to get ont though Manufacturer,and thats slim chance,because there in business to make money,to sell you new motherboard.2.Well what we done if your heatsink clip is real Good set it all in place where it needs to be,take areal small amount of good static tape go around it,it will hold it in place tempory.3.Then put your heatsink on,and clip it on both sides.4.That will work Tempory/or for long time depends on you tearing it apart again.5.Ours x's Laptop sold it to afreind and show hime what we done,and he was o'kay with it.It still working after 6months.Thanks we hope this may help you.
Jul 27, 2010 | HP (5185-0384) CPU Heatsink & Fan
My e-machine's fan just runs constantly and is so noisy. i hate it. can u make it quiet? i put in another 1GB and it didn't help. now we've taken the side off!!! Still loud!!! We bought it in 2005. Piece...
What fan, cpu fan? system fan? graphics card fan?
Either way clear out any dust which could help cool it which may decude the amount of time the fan is on or slow the fan down.
If it wasn't like it new, then its probably dust inside the fan and you wont be able to fix it as most fans will not come apart too easy.
Easier to get a replacement fan from ebay etc.
Dec 11, 2009 | HP Computers & Internet
HP ZV6000 Fan Making Noise
I had a similar problem on my zv6000, but I've tracked it down to the fan in the middle (not the one above the CPU with the heatsink).
For anyone else that doesn't feel like taking your laptop apart twice (once to get the part number and twice to put the new fan in after you get it online, etc.), the fan is a Sunon Maglev GC 056015VH-A. HP doesn't carry them in the parts store anymore, but I ordered mine online from an independent retailer.
Nov 22, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
CPU FAN MOTOR WONT WROK
the fan could simply be clogged and is held stil, or it needs to be lubricated, remove the fan, on the rear there will be a sticker covering a small hole, carefully peel back sticker, dont take it off, it stops dust geting in there, under that sticker will be the bearings, spray a small amount of a general lubricant or oil in there, and turn it with your hand until it is free and easy, mount it back on heatsink and it should work, failing that try a new fan
Feb 27, 2008 | Computers & Internet
HP Media Center M370N (DM163A#ABA) PC Desktop Logo
106 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
