Question about Braun 2540 S Electric Shaver
Opening Braun 2540
Does anybody know how to open this razor? I would like to replace battery but don't know how to open it. I can't find service manual.
Yeap! I just did it violently... :S But luckyly didn't break anything. Anyway, the right way: First screws of course. Then you can open it a little bit, and you can see a white part at the bottom. It moves sideways and releases the cover. Hope you can make it easier than me!
Posted on Oct 05, 2007
SOURCE:
How do I replace batteries
http://www.service.braun.com/line/SH/S5772/S5772_4_CHIN.pdf
Sep 30, 2014 | Braun 390cc Series 3 Shaving System
Can anyone help with some advice for home razor repair?
After dropping the razor it is very difficult to know what the problem is without examining it. Based on the symptoms you describe, I would guess that the the 'drive unit' is damaged. You will find this part available at shaveroutlet.com. See link below. Scroll down the page for installation help video
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
Oct 26, 2011 | Braun 360° Complete 8985 Electric Shaver
I have a braun 5614 razor bought in usa many years ago and now needs new batteries.No one in zimbabwe can help, please tell me how to open razor and change batteries.
There are two round screw covers on the bottom. Pry these out to reveal two screws. Remove screws and then the out case can be slid downward and off. You can then access the batteries
Replacement batteries for model 5614 can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
Sep 12, 2010 | Braun Health & Beauty
I had my braun 2540 off for along time and I want to charge it again and It doesn't charge. What do I have to do?
my braun 2530 will not charge any more how do I get to charge and get to use this good razor to work again it is too early to throw it out yet- hope to get a useful reply.
preben gerstrøm (gerstroem)
pg2@anarki.dk
Aug 14, 2010 | Braun 2540 S Electric Shaver
Batteries run down faster (Braun 7505)
You will find batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Jul 14, 2010 | Braun 7000 Series Foil and Cutterblock
Disassemble a braun Clean & renew razor cleaner
To open model 8985 you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
If replacement parts are required, you will find all components for this model at shaveroutlet.com
Jun 12, 2010 | Braun 360° Complete 8985 Electric Shaver
How do I open the case to change the battery?
There are 2 removable plastic plates on either side of the power entry connector> Pry these off with a knife and remove the 2 screws. Next slide the razor out of it's case. The batteries are soldered in.
Gary
Apr 22, 2009 | Braun 4501 Electric Shaver
The razor head comes loose from the two arms.
I had a similar problem where one of the side covers popped off. I was able to reattach it, by carefully aligning the spring and pushing back into place. If you've lost the pin, you're out of luck. Braun does not make these kinds of parts available for user servicing, unfortunately.
However, the 7000 series models are all compatible with each other in terms of motor, battery, and razor head armature. You could try locating a moderately used example on the cheap (maybe less than $20) and then cannibalize it for the parts you need.
Do NOT send it off to Braun for servicing, as you will be charged much more than the shaver is worth. If it comes to that, you're better off just going with an 8000 series shaver.
Mar 11, 2009 | Braun Syncro 7526 Electric Shaver
Braun 2540 S Electric Shaver Logo
765 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Joseph Hoffmann
Craig
Level 1 Expert
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
