Question about Maytag Neptune MDG5500AW Gas Dryer
Not drying properly
Checked exhaust ok. settings ok exhaust is warm but not hot as it used to be smell of natural gas slightly
  • Maytag Master
  • 8,220 Answers
These plastic blower wheel will get clogged with lint in front of them or they will strip out,get loose, and cause the dryer to be very inefficient. Get the front off and clean out the filter housing. Check the blower for looseness.
Posted on Dec 15, 2008
Vehicle smells like natural gas after stopping when vehicle is hot
I think you are getting a rotten egg smell,not natural gas. I would check for exhaust leaks from the catalytic converter for starters. Have you checked the grill at the base of the windshield and on top of the firewall? folks have been known to drop eggs down there as a prank.
Dec 04, 2013 | 2010 Lincoln MKX
Gas exhaust smell when Hot water heater ignites
Absolute danger here:
1) Call gas company IMMEDIATELY to check for gas leak that can cause explosion and fire.
2) Call plumber immediately to fix improper combustion or improper vent before toxic combustion by-product kills family.
Gas appliances must vent toxic by-product outside and away from home where the gasses will kill the planet instead of you.
Dec 08, 2012 | Rheem RTG-66DVN Direct Vent Natural Gas
My natural gas maytag dryer does not provide hot air to dry the clothes. It apperas the gas is not igniting because after it tries it smells like gas. I beleive it could be the ignition source.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 17, 2011 | Dryers
Our Maytag Neptune gas dryer is exhausting a natural gas odor now... This smell only occurs when it has been running for awhile and never when it's turned off. Also, it ONLY smells outside the house via...
The burner is not lighting right...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have a kenmore 70 series gas dryer. the dryer works pretty normal except the clothes take a little while longer to dry and they all smell badly of natural gas. i opened it up and and i can see the...
Check the vent hose for kinks . Also check the exhaust at the outside to make sure it has good air flow to the outside . A dryer either heats or not . Due to it heats , the only possible problem is vent hose blockage .
Sep 23, 2010 | Kenmore Dryers
LG DLG2526W gas dryer not heating after 1.5 years. Unplugged unit to attempt reset. Cleaned out back vent which did have some lint build-up. Still not heating. Is there a reset button somewhere or do I...
I was having similar symptoms and have finally solved my issue.
We noticed that clothes weren't drying as well as they use to...when using sensor dry they would come out slightly damp (just barely). Intermittently we would smell natural gas in the laundry room. After reading numerous forum posts, I decided to swap out the main control board because many people said changing the ignitor and gas valve didn't fix the problem. I thought that I had fixed the problem as we didn't smell gas for a few weeks.
Well, the problem did come back a few weeks later. I ordered a gas valve thinking that was the most likely culprit. The swap out that part I had to remove the drum which exposed everything in the dryer nicely. It turns out the exhaust tube had dislodged internally and a decent amount of lint was being blown inside the machine. Lint was everywhere.
The lint had built up inside the gas tube and must have caused turbulence in the gas flow which prevented it from lighting properly. I cleaned everything up, reconnected the exhaust tubing and taped it securely before putting everything back together. I didn't replace the gas valve as the original one ohmed out properly. The dryer has been working like new for several weeks now.
I hope this helps other with similar problems.
Apr 02, 2010 | LG Dryers
A lingering natural gas smell after a hot water heater fires up in the basement the unit is Sears Power 12 50 gallon model bought in spring 2009
make sure you have the proper piping for out side combustion air. this is a code in some areas?? this will help dispate the gas smell after the water fires up and causes the gas smell... also might check the flue make sure it is properly installed and venting properlymm
Mar 24, 2010 | Water Heaters
The clothes are dry but have a smell of natural gas
I think your exhaust hose is clogged. Please make sure it is completely free of lint. Remembver to check the outside vent.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Smells hot. does not dry. sticks on 20 min all cycles
just a quick suggestion
check your exhaust outside for proper airflow
Oct 11, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Whirlpool Gas Dryer takes 2 or 3 cycles to dry clothes
did you check ALL lines..in and out for clogs!?
Mar 15, 2009 | Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
124 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
