Question about Panasonic PT-60LCX63 60" Rear Projection HDTV-Ready Television
Needs to locate air filter
I get a display on the screen saying : air filter needs cleaning, call for service. tv will turn off after one hour. where is this air filter located and how to clean it
    Scholar:
  • 101 Answers
It is located top of light engine. left side, fan is on the right.Black plastic vent facing up-wards.Right over a circuit board that has a wire going to the fan.Take out 4 gold screws filter is inside.
You can wash it w/MILD soap and water. MAKE SURE IT COMPLETLY DRY before you re-install it.Or use air in a can.
DO NOT BLOW air into the vent.You will damage the lcd by blowing dust on it. or cracking it if air gets cold. Hold can UP-RIGHT so air is NOT cold. If you need picts. Contact me at toddthetvmd@yahoo.com Hope this helps. Todd
Posted on Apr 03, 2009
  • 944 Answers
All of these projection tvs have an air filter - the bulbs get very hot and require air to circulate to cool them - without a filter you would get an effect similar to insects flying around in front of the set due to dust particles, which are also possibly able to damage the bulb. here is the link for the operating manual for your set if you need it, although it doesnt describe the location of the filter; http://www2.panasonic.com/webapp/wcs/stores/servlet/vProdSupportModel?displayTab=R&surfModel=PT-60LCX63&modelNo=PT-60LCX63&storeId=15001&catalogId=11017&itemId=64594&displayServiceCenter=true# If you are comfortable opening up the set yourself, first try to figure out where the cooling fan sucks air in from. somewhere between the outside of the set and the fan will be the filter - if you are struggling to find it still then try posting us a photo or two of the inside of the set - hopefully we can identify the filter - panasonic/matsushita reccommend very much that you do not replace the filter yourself, there are obviously issues that are more complicated than just taking a mesh screen out and cleaning it, so be careful. Hope this helps some - please post back with photos if you are still determined to try yourself, else if you can give me your general location i can try and find a local service centre that can deal with the problem. :)
Posted on Apr 06, 2007
    Genius:
  • 1,074 Answers
My friend in my years of repairing tv and other electronics components i have never hear of tv having air filter unless it is a new technology that i do not know about,but if your tv is turning off after 1 hour then you are having problem in your power supply crcuit.or horizontal circuit.have a tech look at your tv.only mechanical aparatus use air filter.example vehicle carburator.but i am stand to be corrected.good luck.
Posted on Mar 30, 2007
Tv is displaying to clean air filter, where is the air filter? How do you clean it? Does it have a reset?
Found on the net:
The Panasonic air filter is located BEHIND the removable Front Panel.....it pops off and you should see it located in a "screwed in" panel.
But, it MAY be located on the BACK or side.....LOOK for a Grille with a grey or black foam piece. IF you don't find it behind or beside the TV, then pull off the Front panel.
Now, those foam filters can be removed from the grille-plate to be washed......the best way to wash it is to PUSH the dust out of the filter by turning the Clean-side of the filter TOWARDs your water source (the faucet or the Much-preferred Kitchen Sprayer)....Now get that DUST OUT!
Once finished cleaning just shake all the water out of the foam panel. Snap it just like you're snapping somebody with a towel. Still Moist? Don't worry, the plenum on the TV is pretty long and "moisturized air" won't hurt the bulb......
Reassemble it......
And DO NOT let that filter go that long between Cleanings!! It EXTENDS the life of the bulb when maintained regularly.
Oct 12, 2010 | Panasonic PT-52LCX65 44" HDTV
A screen comes up and says time to clean air filter, Where is the air filter located?
I just experienced the exact same thing. The tv will shut off if it gets too hot, and a clogged air filter will make it too hot. My tv is still under warranty, but I watched the technician do it. He removed the front and back part of the tv. He got down to the bulb enclosure in the rear of the tv, which is where the filter is located. He used my dirt devil and a brush to clean out the filter and the whole general back of the exposed tv. The he put all the pieces back on the front and back of the tv. Hope that helps!
Feb 23, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic rear projection tv air filter
heres what you do remove front panel "little black door below the screen" get some software cleaner "air" clean all in that box that you just removed the cover from also you might try cue tips and alcohol let dry thoroughly put cover back on and turn on tv it should work if the message comes on again turn the power on and off about 6-10 times and turn back on it should turn on and be fine .if that happens again just open the cover and blow with sopftware clean.sound wierd but after alot of experimenting i fixed my tv that i bought as a salvage because of that error message bhope it works
Feb 19, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-44LCX65 Projection TV
There is a filter in the front of the machine, right beside the lamp door theres another one. blow that out with can air will kill the error for a while then you might needs to get it serviced because one of the fans is caked with dirt and if you dont know electronics i would not try to take it apart to clean it.
Mar 15, 2008 | Panasonic PT-52LCX65 44" HDTV
Air filter cleaning
Air Filter Cleaning for Panasonic PT-43LCX64 PT-50LCX64 PT-60LCX64
OK, I purchased the service manual which explains it pretty good. However it is pretty complex with about 45 screws to be removed so if your going to attempt it buy the manual (mine cost $14.99). There are 3 filters, one at the back and two at the front. Once the procedure is completed there is nothing else to do other than switch it on. There are no timers to reset in the software like some other models. So there must either be an airflow sensor or a temperature sensor. I'll look at the service manual in more depth when I have a chance.
I do have a request for someone. The filter at the rear was pretty clean as was the one on the top part of the projector assembly. The one at the bottom of the assembly was dirty. I think that it might be possible to clean the front filters far more easily. So if anyome wants to try it here is a possible solution.
Remove the front panel (silver). Undo the 2 screws on the cover of the projector housing (not the one that gives you access to the lamp. Remove the cover. Carefully vacuum the top dark grey foam filter on the left side of the pojector unit. Next vacuum the bottom of the unit. That's were the main and dirty filter was. You can't really get to it but I'm hoping you might just get enough off to get it working. The TV senses if its clean enough so there's nothing to loose by seeing if this shortcut works. Once the error comes back I will try it myself.
Good luck
Jan 03, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Reset tv after cleaning
Remove silver panel on front marked HDTV and BBE
Open bulb compartment
On the right side of the bulb compartment is the filter compartment
Remove filter and clean
Every 400hours it will prompt to do so.
Comment by Soulvisitor, posted on Jan 03, 2008 Service mode info
Enter Service Mode: With the TV powered off (make sure it's off for a few minutes before trying this, or you'll wait for the customary cooldown period before anything happens if you turn the set off and try this stuff immediately), press and hold both the "VOLUME Down" button on the TV itself and the TV/VIDEO key on the remote control simultaneously for about 7 seconds (they say over 5 seconds in the manual). The TV will be turned on and it will have a screen full of status data atop an active TV channel.
Next, press the SWAP/STOP key on the remote for more than 5 seconds.
You should be taken to a screen that has " LAMP/FILTER/IIC" as a selectable entity. Press the Action key to select it and move to the next screen of info.
You'll see a status screen with the number of Service Mode Resets of the Lamp run time (I inadvertently reset my Lamp to 0 hrs after 95 hours of initial operation, and I'll show you how to avoid that in a minute). You'll also see Total Time, which I assume is total TV run time, Lamp Run Time, and Filter Time, all in hours.
You can backchain to the the prior screens with the Recall button on remote.
To exit this service mode entirely, you must turn off the TV.
You can also enter a different service mode menu to control a number of parameters, as I first learned from Doug McDonald at this link >>
http://www.avsforum.com/avs-vb/show...hlight=pt40lc12 when I was trying to learn how to perform service mode color adjustments.
Depress the "Volume Down" button on the set itself while concurrently depressing the "Recall" key on the remote for about seven seconds, and you'll be taken into "Work Mode". At this point, you can press the Action key, and select "Information", where you'll not only see Input mode (as usual) but also Lamp Run Time (but not Filter time or total run time).
You can enter the more advanced service mode menu by pressing and holding the Volume Down button down on the set itself while concurrently depressing the SWAP/STOP key on the remote for more than five seconds. -- This displayed a Factory Adjust menu, with bunch of settings. See Doug's message for more details. (Do not press Vol Down on the set and PIP/PLAY on remote simultaneously, or you'll reset the Lamp time to 0hrs as I did !)
Unfortunately, the service manual does not describe all the tweakable settings in the Factory Adjust menu.......
Nick Stam
PC Mag and ExtremeTech
Dec 30, 2007 | Panasonic PT-40LC12 40" Rear Projection...
1 second red blink followed by 2 second blink on "status" led
there is a service bullietin related to this.. it has to do with a thermal sensor inside next to bulb..this sensor monitors the temperture of bulb... it says getting hot....this sensor needs to be replaced
Dec 04, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Panasonic
replace with a new aire filter or clean the air filter
vkm
Nov 23, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Air Filter message
Soulvisitor has it right. I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it. Thank you Soulvistor you saved us at least $100.00
Nov 14, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic 50" LCD TV PT-50LC13
I did the following 'press and hold both the "VOLUME Down" button on the TV itself and the TV/VIDEO key on the remote control simultaneously for about 7 seconds (they say over 5 seconds in the manual)"
Will in the service screen I selected the number of hours of the lamp with the down arrows and the action buttons. Then I simply pressed and held the "down volume button" on the remote until the number of hours was 0. Then I turned the TV off, then back on and the message was gone. This worked for me.
Jun 21, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-60LCX63 60" Rear Projection HDTV-Ready Television Logo
430 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
