Question about Canon PIXMA MP130 All-In-One InkJet Printer
Ink cartridge jammed
Canon Pixma MP130 gives me message that ink cartridge is jammed
How can the problem be remedied?
  • 2 more comments
  • lornab29 Feb 11, 2009
    i hahe Canon PIXMA MP130 All-In-One InkJet Printer and it keep saying cartridge jammed can someone tell me what to do
  • PhineasP Feb 19, 2009
    MP130 was working fine then suddenly issued computer screen message "Service error 5100. Cancel printing and press the OK button. If this does not fix the problem consult the manual". The Pixma screen says "cartridge jammed. Press OK". The user guide does not seem to give any solution I can find.
    I have started and restarted, removed and replaced the ink tanks, all to no avail. Any solution greatly appreciated.
    Jim
  • Anonymous Mar 11, 2009
    I can't seem to fix the jammed cartridge !!!
  • debankin Mar 18, 2009
    I have the exact same problem, I need a solution
    Problem Solver:
I just cleaned my rollers and now its working again. I have no idea if its a solution or a fluke but it worked for me
Posted on Mar 18, 2009
Canon FaxphoneB95 gives message"Cartridge Jammed". How can I solve this problem. Need Answer Urgently Please.
Posted on Feb 06, 2009
My Canon Pixma MP130 keeps giving me the 5100 error. Can't even complete the nozzle print test. The ink cartridges do not appear to be jammed as they move. What is the problem? Please help.
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps!
May 22, 2011 | Canon PIXMA MP130 All-In-One InkJet...
My canon pixma mp30 keeps saying cartridge jammed pls can you tell me if i can fix it cos it wont print. thanks
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
  1. You will include printer.
  2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service regime.
  3. select NVRAM ACCESS and further BY OK.
  4. select SET Abs- m level and advance value equal to zero.
  5. select SET Abs- r level (if there is) and also you will establish into zero.
  6. you will turn off printer by button POWER.
Dec 29, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon mp130 ink cartridge jammed
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Sep 03, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I have a canon pixma mp130 and it keeps saying cart. jammed
Press menu to maintenance.....go to cleaning roller....repeat cleaning 3 times....return to copying...hope this helps
Aug 04, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I changed ink my printer showing wrong cartridge
Make sure you are using factory new Canon ink cartridges.
If you purchased re-filled cartridges or third party cartridges that is most likely your problem.
Don
Jun 14, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 "check ink tank" message
Have you put in new ink cartridges? It may be all you need.
Nov 05, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Printer mp130
take the ink cradle out and take the cartridges out. clean the print head on cradle with alcohol, and you might wanna try blowing the ink residue out of the head becuase the black ink cartridge leaks
Jul 10, 2008 | Canon PIXMA MP130 All-In-One InkJet...
I have a jammed cartridge, what can I do
The last two MFP printers brought into my shop had problems from their original setup and opening. Check the inside, anywhere that the paper path or cartridge line touches, make sure there are no small shards of plastic or remaining packing materials like tape or cardboard flakes deep in the printer. There are also small jam sensors that protrude very little from the paper path that if knocked over a little bit can become loose and ironically cause jams.
Oct 23, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
773 people viewed this question
old marine
old marine
