Question about Toshiba 27A50 TV
Intermittent picture and sound Toshiba model 27A50
The picture plays fine for hours then I get a black screen and no sound with a flashing red power light , the TV will eventually power down. Is this a major problem? Is it worth repairing or should I just purchase another TV (don't want to do that)?
I read online that another person had a similar problem and it was some type of cold solder joint. Does this sound like my problem?
5 Suggested Answers
SOURCE: TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
I have a problem
Posted on Aug 11, 2008
andyroid85
  • 7 Answers
SOURCE: Toshiba 32a32 chassis tac 245 powers up for 1 secopnd then red power light flashes.
just fixed one with that problem it was the vertical output ic Q301
that was shorted. try wicking it out. it is a LA7833S.
Postings say to be sure to use the Toshiba part
Posted on Aug 28, 2008
SOURCE: Toshiba 36HF71 has sound but no picture
Same problem with mine. Relays click, sound, no picture and a flashing power LED. I finally found a schematic online. I went through the high voltage circuits and found the power transistor 2SC5570 was shorted out. There is also a pico fuse in that area but my was not open. I replaced the transistor and prayed the flyback transformer was not shorted. It wasn't, I'm watching my old 36" right now. Not a bad fix (17.00) bucks. Wonder what a service tech would have charged ;)
Posted on Jun 14, 2009
rhozel2010
  • 269 Answers
SOURCE: Convergence problem... Could it be bad solder joints???
if you have resolder it and still the trouble exist then that is the time to replace the ic.
Posted on Jul 31, 2009
Toshiba 52L7200U not picture, just toshiba logo
Those flashes are fault indications. http://electronicshelponline.blogspot.com/ Visit the site linked here to get more details. Search the site by type in the brand name of your device in the search box at the top right of the display window to get gathered all the related posts.
Nov 07, 2015 | Toshiba 55L7200U 55-Inch 1080p 3D LED HDTV
Toshiba Cinemax Series HD Black screen - no sound
The red light flashing is usually the set detecting a short, to know if I can or cannot help I need to know the model number of this Toshiba.
Dec 16, 2012 | Televison & Video
My TV Screen just turned off, but I hear the sound, have no menu.
MINE DID THE SAME THING ABOUT AN HOUR AGO. I UNPLUGGED THE SKY BOX FOR ABOUT 10 MINS PLUGGED IT IN AGAIN IT WAS FINE
Jan 31, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Excellent picture for a several hours, then gradually dims.
if this is a old unit the there is serious problem with the display.
check how many times the light blinks and get back to us.
Feb 08, 2009 | Toshiba TP43H60 43" Television
Jan 02, 2009 | Toshiba 36HF71 36" TV
Tv screen get smaller
not the flyback
it is either the vertical ic
or related caps
it is repairable probally between $75 and $100
what size screen and how old (is it worth it? that your call
Dec 20, 2008 | Toshiba 27A50 TV
Picture and sound does not always come "on"
Trimmer, you`ve narrowed it down to a certain section and your absolutely correct that it is a bad solder joint, there are 2 things you can do, first get a bright light and a magnifying glass and go over the bottom of the board and look for it, should be fairly obvious with the magnifier, if not go here and order a can of "Freeze mist" www.partstore.com this is a great "tool" for finding intermittents, it`s coolant in a spray can, have someone watch the screen while you spray in the area of the intermittent, when you hit the bad part the set will work, re-solder the part and any joints around it that look bad, end of problem, good luck with it, BMW Rider
Dec 06, 2007 | Toshiba 27A50 TV
Toshiba 27A50 TV Logo
66 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
