Question about HP Officejet Pro L7780 All-In-One InkJet Printer
How to turn my printer back online????
I cant turn my printer back online it doesnt even have the green light in the back to indicate the printer is online. I know its online in my settings but its not when I print out a test for network on my printer it states that is offline.
  • 1 more comment
  • rmleidl Dec 14, 2008
    my printer will print a test page but will not print anything else.
  • Anonymous Feb 06, 2009
    please help me get connected to mt printer it says it is offline
  • gpapineau May 11, 2009
    i can`t print email or test print it says my printer is offline
SOURCE: canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Posted on Mar 12, 2008
  • 44 Answers
SOURCE: Cannot print on the network
I would print out a menu map from the printer and check the IP address that is set is the same as the one in the ports tab in the printer properties. If this is not the case then change one to match the other. Also make sure that the printers IP address is set manually and not by DHCP because DHCP will change the address every time it is switched on/off.
Posted on May 12, 2009
mahjid
  • 202 Answers
SOURCE: My printer won't print. It says it is offline.
go to control panel and click on added printer and on the the printer itself, right click on the and put it back online
Posted on Jul 14, 2009
  • 355 Answers
SOURCE: i cant print...it says that printer is offline and
check the cable then try
Posted on Oct 07, 2009
trikha_karan
  • 66 Answers
SOURCE: My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
Posted on Nov 10, 2009
Canon i470D Printer will not work. Yellow light
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume", include printer (click "Power").
3. Hold the "Power" button, release the button "Resume" (power indicator / preparedness must turns green)
4. Not releasing the "Power" button, double click "Resume" and release both buttons
-- each time you click "Resume" power indicator / willingness to change color (one-click - yellow, the second hitting - green). U printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow)
-- after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently
-- If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
5. Four times click "Resume" (each time you click "Resume" power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
6. Once you click "Power" to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
For some printers (for example, iP2000) to switch off clicking "Power" again, that is three in a row.
May 08, 2010 | Canon i 470D InkJet Printer
I320: Light on printer alternates between green & amber
Hi there.
Step 1: Manual Temporary
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
6. Release both buttons.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3.Choose (SET DESTINATION 1) And it should be reset.
Sofware Download "After service mode Pls use software for permanent reset
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | Office Equipment & Supplies
The on button keeps flashing and the red light stays on
Try resetting your Canon PIXMA. Here's how:
  1. Turn the printer off.
  2. Hold the button Resume / Cancel (red triangle in the circle), click POWER - indicator lights green.
  3. Release the button Resume / Cancel, keeping POWER.
  4. Click Resume / Cancel 2 times, keeping POWER, and then release all the buttons.
  5. When the indicator light Green - click Resume / Cancel 4 times!
  6. Turn the printer off button POWER.
Have a good evening!
Jan 12, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Low toner light
check the tonner placement is correct
Jul 28, 2009 | Office Equipment & Supplies
HP 2550 will not print. Green light flashes. I'm
If the machine is making "working noises" while it flashes, it is most likely calibrating. A good way to find out if the problem is due to connectivity issues with your computer is to turn the machine off, unplug for 1 minute, plug back in and turn on. Wait until the light is solid, indicating its ready to go, and then press and hold the green button until the lights flash. It should produce a demo print for you. If it doesnt, the problem may be with the printer, not the computer. Also, check in the "Printers and Faxes" settings in the control panel (if you are running windows) to see that the 2550 is set as the default printer.
Feb 20, 2009 | HP LaserJet 2550n Printer
I unplug my hard drive and now I cant get my computer to start up
Try switching your power cable with te one from another pc, if that doesnt help check wether the on/off button on your power supply is turned on. If that doesnt help either I'll need more info about what those lights indicate.
Feb 17, 2009 | Compaq (261671-001) Motherboard
Canon Pixma Printer trouble
hi dear
try with this metode
Waste Ink Counter Reset. Manual for Service mode
should be orange.
oke try to print
thanks
cropp
Mar 17, 2008 | Canon PIXMA iP1600 Printer
Canon iP90 Color Cartridge
Actually this just happened to me tonight as well. Fresh color tank doesnt help. Deep cleaning mode doesnt help. Even physically cleaning the input side of the head doesnt work. Cyan just 100% died today, while the other colors continue fine.
Looks like a print head replacement job now, but so far I cant even find anyone selling iP90 parts online.
The iP90 is now getting consistently terrible reviews on Amazon.
Jan 16, 2008 | Canon PIXMA iP90 Mobile Printer
Hp color laser jet printer 3000n
Try this. BTW, the Button with the "Check Mark" is the Enter button on this.
1). Switched the printer off.
2). Press and hold Enter button while turning the printer ON until CONFIG LANGUAGE appears in the Display.
3). After the power-on self test, lang=English (French, in your case) will appear. Press + button until the desired language (English) appears in the display.
4). Press Enter button to save your choice. An asterisk (*) will appear next to English to indicate it is now the default.
5). Press Online button. The On line indicator will be lit, and display messages will now be in English (you selected).
if that doesnt work try this
press...
green enter button once
right grey arrow button once
green enter button twice
then grey arrow button on right or left of green enter button until you see the language you want.
Select by pressing green enter button
Finished.
Jan 10, 2008 | HP Color LaserJet 2600n Printer
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
864 people viewed this question
Seeker5211
Seeker5211
