Question about Weather King 10AJA2501AH Air Conditioner
My furnace makes a loud noise when it is going off
Weatherking mo# 1opjb48a01
  • Anonymous Dec 22, 2008
    same problem, furnace makes the loud noise when it's going off. Had it inspected just 2 mos ago, and it's working well, but had the noise problem then. I was told it was old duct work, but it sounds like it's getting worse. doesn't make sense...??
  • Stephen Evans May 11, 2010
    is your filter clean?
  • 70 Answers
If it is a bang could be return air drop. not right amount of returns in house.will not harm anything. you could cut a return in the drop in the basement
Posted on Oct 04, 2009
Ever limit switch i changed in my Weatherking furnace, it breaks the switch, what could cause this?
You need the model number of the furnace to determine what the flashing light is telling you. Many times the part that looks to be at fault is not the true fault in the furnace. A slow running blower could cause the limit switch to trip. The circuit board tells you that the limit tripped, but the real cause is the motor or clogged filter.
Jan 02, 2016 | FACTORY AC PARTS Limit Switch Double Pole...
My furnace makes a loud noise on start up
What kindof sound? Is it a squelling kind of sound?
Jan 03, 2013 | Heating & Cooling
Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Feb 03, 2010 | Aprilaire 550 Humidifier
My weatherking furnace shuts off, i can hear clicking from the gas relay, but don't know if it is the relay or the pressure switch. when i reset the power it comes on again.
weatherking furance shuts off, i can hear a clicking noise from the gas relay, dont know if its the relay,pressureswitch or gas valve.
Dec 27, 2009 | Heating & Cooling
Weatherking furnace flashing 5 times.......
Sounds like it it isn't the igniter but probably the pressure switch. You can only tell by the clicking noises as they system goes through it's safty checks prior to the call to the igniter.
Mar 05, 2009 | Weather King 12AJA4801AH Air Conditioner
WeatherKing Acclaim II
  1. The sensor that tells the furnace whether the gas is lit has got build-up on it and is giving the furnace bad information.
  2. The flame sensor is often a single wire or rod that sticks up in the center of the flame.
  3. You can shut off the furnace and the gas and clean the sensor with some sandpaper.
If that still doesn't work, the sensor may need to be replaced.
Please rate this solution.
Jan 16, 2009 | Heating & Cooling
Loud noise when furnace starts but furnace won't come on.
Your fan delay relay has failed and must be replaced.
Jan 16, 2009 | York Yankees Bedding MLB Comforter
Finding the cooling contactor on weatherking acclaim II gas furna
the "y" terminal sends the hot leg of the 24 volts and the "c" terminal sends the common leg to the condenser..
Nov 15, 2008 | Weather King Heating & Cooling
Loud noise
Replace the water valve... It"s vibrating when closing. Do you have hot water feeding the unit?
Oct 22, 2008 | Aprilaire 550 Humidifier
Weather King 10AJA2501AH Air Conditioner Logo
234 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
