Question about Brother HL 5140 Laser Printer
Help please. can't print: paper light flashing even though there is paper in printer
Printer can not print using automatic paper feeder. The status light is on and the paper light is flashing. There is paper loaded and I have pressed the GO button but still no joy. It prints using the manual feed. Any help will be very much appreciated. many thanks
  • Anjula Dec 11, 2007
    My printer has stopped printing too. Status light is on, and paper light is flashing. I have checked everywhere for a paper jam, and have found nothing. Printer will print using manual feed. I've checked the tray settings, and everything seems fine. Any ideas? Are these things only made to last 1 year? What a waste...
To fix the NON EXISTANT paper jam:
Status light is on, paper light is on - you can hear the paper feed trying to "grab" the paper, but it can't,  and status light goes Red.
Take out paper tray
Reset the blue paper holders, move them tight against the paper so the paper is snug against all blue barriers. Cause: Somehow the blue paper holders got dislodged and the paper is not snug so the feeder is trying to grab paper that  is slightly out of reach.
Posted on Oct 24, 2007
I had a jam in my machine before the paper made it into the exit area on the top. It was hard to pull out and I almost tore the paper. After that the Status light was red and the Paper light was blinking and the machine would not print. It was only after I opened the back, pulled down both little blue leavers next to the inner walls, then pushed them back up into their original position, and then closed the back cover did the machine cycle back into ready mode with the Status light green. The next day at work when I was talking to the copier/printer guy I found out that anytime there is a jam that’s hard to pull out on this type of printer, pull those two blue levers down before you remove the paper and it will be easier to get out. Also, these machines must require this action so that the machine knows that the paper was properly removed. Works for me.
Posted on Aug 07, 2010
Perhaps the word processor is set to Manual Feed, instead of "Tray" or automatic. If this is a document in the setting, the printer will wait for the manually fed paper, no matter how many times you press "go."
Posted on Jun 06, 2007
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
Blank page feeding during print job
Please adjust paper size in printer properties.
Oct 09, 2008 | HP Deskjet 6940 InkJet Printer
When press print, the status light flashing orange. It print for a while then the paper light flash yellow, then it stop. The printer print up to half a page the it stop. Check printer and turn printer...
the flashing amber status light is normal indicating data going from computer to printer.the flashing paper light indicates a paper jam or out of paper. A sensor maybe not working properly or sticking. If your model number ends in a D check
Jul 16, 2014 | Brother HL 5140 Laser Printer
It won't print and the light keeps flashing. I lost the instructions!
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Feb 13, 2012 | Lexmark X1240 All-In-One InkJet Printer
Lexmark x5250 flashing green power light
Jan 25, 2012 | Lexmark Office Equipment & Supplies
The orange paper light with the arrow keeps flashing and my ink cartridges wont come to the center
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
10. Load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 18, 2011 | Lexmark X2670 All-In-One Printer
Is only blinking and not printing when i try to print the usb conect successfuly to the compter but the printer is not printing the light is only blinking
The blinking light could indicate either a paper jam, communication problem between one of your cartridges and the printer or a short in one of your cartridges. Please follow the steps below to identify and fix the problem:
  5. Unplug and re-plug the printer into the power source to reset it.
Aug 11, 2011 | Lexmark X1150 All-In-One InkJet Printer
Printer and status light flashing - feed not working. Have checked cables.
  11. Try to print again.
Jul 26, 2011 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X75 not working - flashing power and status light - no paper feed.
Jul 26, 2011 | Lexmark X75 All-In-One InkJet Printer
Brother HL 5140 Laser Printer Logo
2,077 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
