Question about Husqvarna Sewing Machines
Sewing machine only sews backwards
When I push in the "backwards" button, the feed dog doesn't move at all.
  • 30 Answers
Make sure that the machine is in straight stitch forward and the stitch length is the highest level that it can go. If that doesn't make it go forward, you will have to use the old hair dryer trick. Take the top lid of the machine off and heat the inside with a heated hairdryer. Work the stitch length and the reverse until it frees up.
Posted on Dec 15, 2008
2 Suggested Answers
  • 208 Answers
SOURCE: started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Posted on Nov 14, 2009
Does my Brother SQ9185 sew backwards other than the push button backstitch?
Use the reverse button. That's what it is for. Sew forward and then push the button and sew in reverse.
Machine Darning Jeans Shirt
If you have a darning foot, you can use it (drop the feed dogs) and then you manually move the fabric around while stitching.
Learn How To Mend Clothes with Machine Darning
Oct 01, 2016 | Brother Sewing Machines
Problem with feeddog on my sewing machine
When the feed dogs have been dropped, some machine feed dogs will not become activated (rise & move backward & forward) until stitching is begun.
Be sure the stitch length is set high enough to actually cause the feed dogs to move forward & backward.
If they still do not move and your machine is mechanical (not computerized), the old oil may have solidified and is preventing them from moving. A good cleaning and oiling may be required. Other than that, it may need service.
Aug 26, 2016 | Sewing Machines
Prelude. How can I adjust a feed dog to go left to right?
Sewing machine feed dogs generally do not move sideways. They move only forward or backward. Embroidery machines will stitch in all directions but only because they use hoops and not feed dogs to move the fabric. If you need the stitch to go a different direction, you can try rotating the fabric. Free motion quilting uses your hands to move the fabric under the needle but the feed dogs are not in use.
Mar 10, 2016 | Sewing Machines
My machine will not move forward.
Sewing machines have a "free sew" that allows you to move a hoop by your own choice any way you choose. This means the feed dogs are below the plate and will not move the material forward or backwards either. You need to find the button and switch it to feed.
Dec 08, 2014 | Sewing Machines
The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
Mar 19, 2013 | Kenmore Sewing Machines
What does feed dog lever do on my Elna 6005 Heirloom sewing machine? Do I need to alter it for sewing very thick fabrics/seams?
Feed dog lever should lower the feed dogs, these are the teeth that grip and move the fabric foward and backwards as the needle goes up and down, they are under the needle plate.
Only time you would lower the feed dogs is if you want to do free motion embroidery or darning perhaps.
So no, don't touch for normal seam stitching. If you are sewing very heavy fabric you may want to lessen the pressure on the presser foot a little (if your machine has this adjustment it will be a knob on top of the head above the pressure foot area).
You may find that your machine doesn't really like very thick fabrics. Sewing something like upholstery weight with a domestic machine is pretty ambitious; an industrial strength machine is best bet.
Nov 09, 2011 | Elna Heirloom Edition 6005
Feeding device (with "teeth") does not come up
Reengage the feed dogs by pushing the feed dog button AND manually turning the flywheel towards you through one stitch sequence, you should see them moving back above the needle plate after a stitch has been made.
Oct 10, 2011 | Husqvarna Viking 1
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
296 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
