Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
I have a Kenmore triple task electric stove but no user manual
I need to know how to use the self cleaning feature my stove has so I can clean the oven, please help
  • Jyackle5
    Jyackle5 May 11, 2010
    need model # to help you.
4 Suggested Answers
SOURCE: self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Posted on Dec 09, 2008
jackiaria
  • 350 Answers
SOURCE: I have an electric Maytag stove/oven but don't
Dear cooper1914,
There are two types of Ovens that clean themselves.
1) A Self-Cleaning Oven which usually gets locked 1st then set on Self-Clean.
2) A Continuous-Cleaning Oven which is constantly cleaning
Some people prefer the old fashion clean by hand with degreasers but I prefer Self-Clean or Continuous-Clean as there is no need for harsh potent cleaners!
If you have a Self-Cleaning or Continuous-Clean Oven Do Not Clean With Cleaners as it will ruin the flavor of your oven!
Click on the following link for more info @ http://www.essortment.com/all/cleanoven_rbad.htm
Maytag Customer Support Manuals @ http://www.maytag.com/support/manuals_literature.jsp
jackiaria
Tuesday 02-24-2009 11:13am EST (USA)
Posted on Feb 24, 2009
heatman101
  • 43501 Answers
SOURCE: I have a triple task Kenmore stove with the self
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Apr 11, 2010
After cleaning the outside surfaces of the stove, the oven door is locked and does not unlock if we push the stop button. Display reads LOC. No self cleaning cycle was initiated. The stove is a Kenmore...
What about child lock? Read user manual or try holding button for 10 seconds, might be two at once.
(I bought a $200 control board and travelled 150 kilometers for that one....)
Oct 15, 2013 | Kenmore 49043 Electric Single Oven
I recently bought a home with a Kenmore Self Cleaning Ultra Bake Oven but no manual to be found. Serial # 9755994 Model 880 655 124PO. I would appreciate any information regarding this stove and how to...
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 09, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
heatman101
Apr 13, 2010 | Ovens
I have a triple task Kenmore stove with the self cleaning feature, my oven worked fine till I cleaned it one day and now it wont heat up. I have taken the elements out and had the tested and they are fine...
heatman101
Apr 11, 2010 | Ovens
Self cleanning oven - door is lock and I can not get it to open
if you open the lid on your stove,you will probably be able to reset the
switch manually (the latch).with the lid up its located toward the front
behind the safety latch.(by no means attempt to force,bypass,or disable this
switch)this is a safety feature designed to protect you from the high temps
generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Try this, and let me know if it worked, I am trying to help someone else with the same problem, that stove is Model, 790
Mar 07, 2009 | Kenmore Ovens
I have locked my Kenmore self cleaning stove, now it won't open
Sorry you gave the sereial # for the oven. Need model #. Here is an manual that might work for you. cout and past in address bar.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0309524.pdf
Or you can go to this web sight and look up your oven.
http://www.managemyhome.com/mmh/answers/Answers.action#l4q106688
Good Luck
Dec 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric stove
Hello d_i_a_n_a18,
In order to put most ovens into the self-clean mode, there are a series of steps that must be initiated in a specific order. On most units the oven control needs to be set to bake or clean and the temp. control needs to be set to clean and the door lock mechanism must be engaged for everything to work. I would suggest that you consult the user's manual for directions for your specific model. If your manual is not available, check on line at the kenmore parts web-site and you can usually get a PDF version of your manual. Good luck.
Nov 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Self cleaning oven directions
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
430 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
