Turned on my wipers and the driver side stopped working
SOURCE: Driver side wiper not working!
its a small, white plastic "nut" on the wiper transmission arm- find one in a junkyard-snap it in and you can solve it for 2 bucks-takes about 10 minutes to do. Cant get the part separately without buying the entire transmission, which you dont want to do- common problem with cavaliers and sunfires of this year.
SOURCE: Driver's side windshield wiper stopped working.
Hello, I would say that is exactly what has happened. If you can move the wipers with no resistance it's likely one of the bolts has come loose. Both wiper arms are linked to one wiper motor.
SOURCE: 2002 Chevy Tahoe-Drivers Side windshield wiper not working
There is a bar that connects both your windshield wipers together check that to see if it is broke or has come unscrewed. Should be underneath the hood upagainst the firewall.
Testimonial: "Thank you. That was the problem the bolt was loose"
SOURCE: 1998 chevy caviler windshield wipers arent working correctly
this is due to the misalignment.when it is in use.it pressures the motor to move but the motor gets misaligned as motor may be weak or very old and causes this issue.
replacing the motor solves the problem.its a common problem.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
SOURCE: windshield wiper driver's side went limp wind
THe wind doesn't just push the power arm off, it must be broken and will need be replaced, You need to check if the actuall bracket that holds the arm is broken as well. It has teeth on it which when the arm is put on it lock in place with a clip
