Question about Home
Water valve jammed
The cold water valve in the airing cupboard is jammed in the open position.
I can't shut the valve in order to replace the tap washer in the bath.
What do you suggest I do?I did not want to use too much force in case I broke something.
    Scholar:
  • 44 Answers
Hi it sounds as though its stuck due to verdigris & scale, a common problem.if you break it all thats likely to happen is the spindle will shear off, which will mean a new one anyway. If you dont want to do this I suggest you turn off the water to the storage tank & open the cold taps till the water stops you can then replace the washer.whilstthe water is drained i suggest a new valve to be fitted for future servicing etc, also it might pay you to fit a service valve on the supply to the tap.
Posted on Dec 15, 2008
I have a Whirlpool water heater, the drain valve is plastic and has split into at the hose connection, I want to replace the plastic with a brass valve. How do I drain the water?
Most water heaters have a drain on the bottom where you can hook up a garden hose and run out side. Or you can get an air compressor and hook the air line to an open hot tap and put pressure and run the water out another hot tap. Close all taps but these two and make sure the cold water inlet to the tank is shut off.
Jun 26, 2017 | Whirlpool Water Heaters
Cold water valve not working. have checked that water is at outlet of cold water tap. Can you help? thank you
Water Valve Test
When in Diagnostic Mode, the WASH TEMP UP button turns the hot water valve on. The Hot LED is on when the hot valve is on. The WASH TEMP DOWN button turns the cold water valve on. The Cold LED is on when the cold valve is on.
DIAGNOSTIC MODE
Turn the power on at the power point but off at the machine. Press and hold the WASH TEMP DOWN button and then the POWER button until the machine gives 2 short beeps and lights up. Release buttons when the beeps indicate diagnostic mode has been entered.
There maybe up to 3 filters cold water line. There is sometimes 1 at each end of the water hose itself and also in the valve which can be removed with pliers. (see picture)
Undo the 2 screws at the back of the buttons panel
Undo the connection of the valve
If you are good with a multimeter check that there is about 65 ohms resistance across the terminals of the valve. If not, then replace the valve.
Also sometimes the workings inside the valve can jam shut so replace the valve.
Dec 27, 2014 | Fisher and Paykel GWL11 Top Load Washer
My hot water tanks turns on but no hot water. Their is a lot of air in the line
Double check that by-pass valves are in proper position, as well as any winterizing valve is in the off position. Some units have a winterizing valve and hose to put in jug for winterizing, that needs to be shut off otherwise it will suck air. Back of water heater- lower fitting is for cold water in, valve should be open, and top fitting is for hot out, which should be open as well. Any valves that may be in between those 2 lines such as a "t" between lines should be in off position. Keep in mind, water heater has to fill first before any good pressure will come out taps. I normally open bathtub hot tap because it\'s less mess and let it run until i get good steady flow from faucette, then do the rest, hot cold.
Apr 18, 2014 | Fleetwood 2008 Terra LX 31M
Changing hot tap washer
Hi, if you have a mains pressure HWC, all you need to do is shut the cold mains off either from your cylinder cupboard or on the street. Shutting it off on the street is probably better as things like shower valves tend to pass water through and start a back feed.
Sep 20, 2013 | Water Heaters
I have an Atwood water heater G6A-7E, heater heats up but no hot water flow after 15 seconds...Flushed system with water and air, put water to it and the hot water flow stops after a few seconds....
First check that any by-pass valves are in proper position. Remember, cold water has to enter in bottom fitting at back of tank, and hot water comes out at top fitting. Thus any valves that may be there, need to be in open position, and any valve between those 2 lines will need to be closed. If all valves are in proper position and working as they should, I would suspect you have a faulty check valve between top (hot) line fitting and tank. One easy way to check that before replacing it, would be to shut incoming water source off, whether running off pump or hose attached outside. Then relieve all pressure in system by opening taps until all pressure is gone. Now, go outside and open pressure relief valve carefully ( in case it's hot ) and make sure pressure is relieved there as well. Now, carefully hold pressure relief valve open while you have someone turn water back on, and see if you get good flow from pressure relief valve. If you get good pressure coming out of there, that tells you your tank is getting full, and you have water coming in as needed, so problem has to be on hot side ( top fitting ) and/or onward from there, which would be check valve fitting at top next to check. Remove the check valve and If you don't have a new check valve to try it, just put a short galvanized 1/2" pipe nipple in there for now if needed and that should do it, just attach your fitting directly to nipple. Before you do this, make sure you have removed all aerators etc on taps that may be plugged and tested pressure that way as well just in case. I have seen all of them plug up at same time before. If you remove them and get good pressure, then problem solved.
Nov 06, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have a rheem 21v50 hot water heater and it is dripping from the spout on the side. How do I stop this slight drip?
Hi, W/D here.
What you are describing sounds like your t&p (temperature and pressure) safety valve, and resetting one involves some risk. You need to have a plan B if resetting it doesn't work.
Plan B: Locate the valve above the water heater. This is the cold water inlet. Locate the gas shut off knob.
We'll execute plan A. Make sure that we are talking about the t&p valve. It will have a tag attached to it, listing the maximum pressure and temperature for the valve. The valve will also have a lever on the top of the valve, attached to a pin.
Try tapping on the pin that the lever is attached to. These aren't hard knocks, but about the amount of force if you were hitting a tack with a small hammer. Just a few taps, then wait. If this seals off the leak, you're done. If not.....
Get a pair of gloves on before proceeding from here. What you can do is lift the lever on the t&p valve, letting some water discharge out the piping. Caution here, the water can be very hot, so you want to protect yourself. The intent here is to flush water through the seat of the valve, clearing any debris out of the valve so that it can seat properly. There are three positions that you can put the lever in, the ready position, which is it's normal position, partially opened, where you lift the lever until you get water, and locked open where you lift the lever and it stays open when the lever is about 90 degrees opened from the ready position. Get something to catch the water if you need to, Place a washcloth in the unbreakable container to reduce the amount of splash. With your gloves on, lift the lever slowly until you get a steady flow of water out of the valve, then release the lever. If this stops the flow, again, you're done.
If neither of these methods resolve the issue (tapping or flushing), then the valve will need to be replaced.
IF THE LEAK GETS WORSE: (Plan B): Close the water inlet valve to the heater described above, and shut off the gas control knob. Relieve the pressure off of the tank by opening a hot water faucet that is fed by this water heater.
Best regards, --W/D--
Please rate this solution so that we may continue to help others. Thanks.
Feb 21, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Only about a cup of hot water will come out, then it gets cold.
You need to check 2 things. First, go outside and carefully open pressure relief valve at top of tank,(careful in case hot water spurts out) and make sure there is water in it. Second, look at back of tank inside RV and check your by-pass valves(s) for proper positioning. Cold water enters the water heater at the bottom fitting, so that valve has to be open, as well as leaves water heater at hot fitting at top of tank (the highest fitting) so that valve as well needs to be open. Any valves that may be in between those 2 water lines need to be closed. I am assuming that the heater starts runs, shuts down etc, just not running any hot water through hot side of taps, correct?
Jan 18, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
My suburan hot water in my 5th wheel camper only makes warm water, never hot. what is the problem?
First, let water heater heat up until it shuts itself off. Now carefully, ( it should be hot) open pressure relief valve slightly and catch some hot water in a cup or container. Compare it to what comes out your tap, that you say is warm only. If that water from pressure relief feels hotter, then check your by-pass valves for proper operation and position on rear of water heater, as it may be in a position that is allowing cold to mix with hot, creating warm. Cold line will go direct in the bottom fitting and hot will come out top fitting, and make sure any valves in between those 2 lines are in off position. If all is well there, or water from pressure relief is only warm as tap as well, then buy a new thermostat and ECO for that particular model water heater from RV dealer/service center, and replace them. They are behind rubber cover on upper left side on water heater. When cover is off, they are held against tank by 3/8 nut. When you replace it, snug nut up good but be careful not to go too much and snap that small brass stud that nut goes on. Pay attention to position of old one, so new one goes same way.
Nov 06, 2010 | RTO Suburban Rv Water Heater Dsi Gas Valve...
When I turn on the cold water tap in the Bathroom Sink the water comes out in a very slow drip or not at all, the CW bath tap is ok
Confirm that the shut-off valve under the sink is open all the way. If it is, then close it and remove the cold water tap. If this is a single handle tap you will of course have to turn off the hot water shut off under the sink too.
With the tap removed and a bucket and towel handy, open the cold water shutoff just a little bit. If water comes rushing out, the problem is obviously with the tap. You may be able to clean or repair it, or you may have to replace it.
Mar 19, 2010 | Home
Water does not shut off. Water flows constantly
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
©2006 Publications International, Ltd.
If an inlet valve is faulty, check the water connection and the
valve screens. Try gently tapping the solenoids;
if this doesn't work, replace the inlet valve assembly.
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
Aug 29, 2009 | GE WBVH6240F Front Load Washer
Home Logo
261 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
