Question about LG Flatron L1951S-SN 19" LCD Flat Panel Monitor
LG Flatron L1951S-SN 19 in. Flat Panel picture problem
Hi all When I turn on said monitor the green light comes on and for a split second I get a picture,then it dissapears and the screen goes blank.The green power light stays on but nothing.It will do this every time I turn the monitor on without fail.Any suggestions would be greatly appreciated.
  • js2ndwind Jul 17, 2008
    LG Flatron 22" wide screen has similar problem. Sometimes the monitor comes on for awhile, then goes black. I swapped it with another monitor and determined that it is a monitor problem, not a graphics card or driver problem. Sometimes I can turn monitor power off for a few minutes. When I turn it back on I have just enough time to close any programs on the monitor before it goes black again. Now, my second LG monitor does the same thing. Except, before it goes dark, I get a "going into power save" message. Nothing will bring it out of that. 2 bad LG monitors out of 2. Doesn't say much for LG quality.
  • 624 Answers
When the picture disappears again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
Posted on Mar 16, 2007
SOURCE:
My monitor comes on for 2 seconds and the goes blank. i get a dsub analog message
This is the technical fault i.e any IC damaged. better take it to the service center or any technician.
Aug 29, 2011 | LG Flatron L1951S-SN 19" LCD Flat Panel...
I Switch the monitor on, picture comes on for 5 seconds then goes off. After switching it off and on again it does the same thing?
Power board capacitors failing, what you are getting is the inability of the capcitors to hold the charge necessary to power the inverter to fire up the screen, means investigating and replacing the faulty ones
Jan 29, 2011 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Turned my tv off last night and then when i tried
power supply has blown. you need to replace the bad capacitors on it. common problem
Jan 01, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
When I turn monitor on the blue light doesn't come on anymore
check the power at the wall and at the back of the monitor, if all is fine then i believe you might need a new monitor
Dec 29, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
My monitor has developed vertical green lines i have tried changing the colour without result
Unplug your monitor cable. If it still has green lines it is the monitor if not then the video card. Hope this note helped you.
Dec 04, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Screen flashes only for a split-second (as a second display for an iMac)
The inverter is faulty.If your Monitor is powered by a mains'kettle' type lead,then it MAY be repairable,provided you can find someone to do it.If you have an external power supply,then the chances are you have a separate inverter,and it is doubtful whetther you can find the fault or a replacement circuit board....which is why we have become a throw away nation !!
Streched picture
what resolution are you running your monitor at, seems like they need to be lower, try 1280x1024
Jan 01, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Logo
373 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
