Question about Creda W120VW Front Load Washer
Creda excel 2000 skips spin and rinse cycle
Would try clearing filter but don't know where it is.
  • abigailapps Dec 15, 2008
    Thanks for the instructions, found filter no problem just waiting for assistance to reassemble before seeing if this has solved the problem. Thanks also for responding so quickly I have a 3 week old baby so washing is piling up! Abigail
  • Creda Master
  • 3,463 Answers
The filter is located in the sump hose at the rear of the washer.
Remove back panel and undo the clip that holds the large black hose onto the rear of the drum .
Inside it ,you will find the filter.
Remove and clean.
Plz leave feedback for this solution.
Thanks.
Posted on Dec 14, 2008
My creda ww100fw washing machine will not rinse spin or empty.I think it may need filter emptying but it was only cleared by washing machine engineer 3-4 months ago!which cost £40.00so would like to know...
if not at front then at the back, usually has a plastic cover that has to be removed with filter attached. it may be that ur pump propeller is blocked or broken? However I would also check the motor coupler or belt depending on direct drive or belt drive, also check clutch and the door switch , check with multi meter for continuity. any of these can stop it from spinning and thus no draining?
Mar 09, 2015 | Creda Washing Machines
My creda simplicty washing machine W200FW) is not finishing programs - it spins and fills but doesn't end - on a rinse cycle it just keeps spinning with water in, on a spin cycle it will drain but on
This is sometimes caused by water not exiting during or at the end of the wash. I have also encountered door lock issue for the same reason.
Jan 21, 2015 | Creda Washing Machines
Hi.My washing machine will not rinse or spin the clothes and am wondering wether it could be the double cellanoid valve as this has been mentioned in chatrooms and forums?
Even if the valve were faulty, it would not stop the washer from spinning.
You can double check this, by selecting spin only, if it does not spin then
I would recommend that you locate and clean the filter, and also check the carbon brushes in the motor, as both these factors have a bearing on it performing correctly.
Please leave any comments you may have regarding my suggested solution.
Thankyou.
Nov 24, 2009 | Creda W100FW Front Load Washer
Maytag washing machine skips rinse cycle
I found this problem with mine intermittently and it was because i had filled the machine too full that it was too heavy to initiate the spin. maybe try a lighter wash?
Jul 03, 2009 | Maytag Washing Machines
LG WD 8013F drains then won't spin
  • Hi,
  • Try these:
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
please rate my suggestion...
May 21, 2009 | LG Washing Machines
Dial keeps turning and clicking
sue worth having inlet valve checked also have heater checked at same time ! is the machine draining ok !! if not there could be blockage in drain system or faulty pump good luck- regards bob btw
Feb 26, 2008 | Creda IWD12 Front Load Washer / Dryer
Freezer before Rinse
you hav'nt said if it drains. the problem just may be that you have plumbed drain hose onto a spigot on the sink drain and spigot is blanked off
Apr 24, 2007 | Creda W120VW Front Load Washer
Not Pumping out water
Possible your outlet filter is blocked. After disconnecting electrical input from wall socket, remove the back panel of washer to see if the pipe from the tub is blocked, clear, also check the outlet filter, clean. If u have the users' manual check how to clean your outlet filter
Nov 14, 2006 | Creda W120VW Front Load Washer
Creda W120VW Front Load Washer Logo
160 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
