Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
I have lost key
Where might I find a key ...I have food inside..
Thanks in advance
  • the5boyds Apr 14, 2009
    I have lost my Key and it is full inside!!!!!!!! Help
  • 71 Answers
Check with dr fixit on the repair providers
Posted on Dec 14, 2008
Our Frigidaire frost frost free upright freezer from day one has frost build up on the food inside the packages. The frost is not a problem in the freezer itself, but on the food. Freezer burn occur
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Sep 30, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hi all My fridge freezer seems to have a problem.
increase the thermostat to a more cooler one, ideally at -5 F
Jan 02, 2011 | Freezers
Just got up this morning and my freezer is hot to touch on the top and sides. Also, the food is defrosting. What's wrong???? Thanks in advance for any response.
check for dust on the condenser coil or if it has a condenser fan is prob not spinning try to free it up by turning it by hand now that's if it has a fan on the outside of the freezer
Sep 30, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
Fridge freezer problem
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Jul 14, 2010 | Freezers
Ice crystals in food bags
shows that you have food that is still warm/wet inside the wrappers.they are frosting up inside the bags.....will cause frezer burn if kept too long....
May 17, 2010 | Freezers
Not cooling, but fan inside running
On a top-freezer when the drain stops up water will back up turning to ice and eventually filling the air ducks with ice blocking airflow to the fresh food section causing it not to cool. You will also see a water leak inside the fresh food section. To fix this, remove the evaporator cover, (back or bottom of freezer) and then remove all the ice. Once all the ice is removed, you need to unclog the drain. I do this by forcing hot water down the drain with a turkey baser but you can use any squirt bottle, I have even used the water hose. Once the drain is clear, mix water and baking soda and pour it down the drain to prevent this from happening again anytime soon.
Apr 06, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have lost my turnkey for an Imperial Upright heavy duty Commercial Freezer. It is locked and I have no way of getting inside... Where can I get one?
you can visit the website of the company and make a request for the key or get the door forced it to get open and get a new locker key for it.
Feb 16, 2010 | Amana 19.7 cu. ft. / 558 liter Upright...
Ice builds up inside packages in freezer.
This is the moisture coming out of the food. It is what causes freezer burn.
The problem is made worse in frost free models by the defrost cylce. Best way to slow it down is to use vacuum bags or freezer bags. Also above 0 F food deterioates faster and below it gets freezer burn and the moisture problem faster.
Mar 22, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Freezer
The condenser or high side is built into the side walls on these modern freezers and refrigerators in many cases. It is normal for the outside walls to be hot when the unit is working. Frost on the inside of the sealed packets of food is from the moisture content of the food. Running the temperature setting to cold will accelerate the moisture freezing to the inside of the food packets. This also is a normal condition.
Sep 15, 2008 | Freezers
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
167 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
