Wiring diagram going to the key switch
SOURCE: wiring diagram Ignition switch
try autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
SOURCE: ignition switch diagram 65 mustang
If its not on the steering column, you can figure it out using an ohmeter on the switch leads. Actually, you could figure out the one on the column that way too! just think about what the switch does in each position and attach wires that do it to the post that does it! IE: starter solenoid wire goes to post that is hot when key is turned all the way to start. Main hotlead is the one that is common to all switch positions. run and accessories is to the post that is hot with key on, accessory only is the one only hot with key turned backwards.
SOURCE: 87 regal ignition switch wiring diagram
Thick wires at IGN SW .... Red(s) - supply power from the battery to the IGN switch ... Pink - ignition supply ... Orange - Accessory power ... Purple most RWD sometimes (Yellow most FWD) - Starter .. Did I miss any? It's been a while The thin wires on the IGN swich are for key sense and VATS (if applicable)
SOURCE: need wiring diagram
Go to autozone.com and register they have good wiring diagrams for your truck.What I saw was all the relays going to ground so you should have 12V coming off the ignition switch.
SOURCE: I need the wiring diagram for a 1982 Buick Regal,
The black wire is usually the ground, that'll be the center connector. Use a jumper wire to go from the front position on the switch to one of the other wires going to the motor. (it's only 12 volts). If the window goes up, you've got the right one The other one is down. If you still need a picture of that, your Buick parts department will show it to you if you say pretty please.
