2005 Jeep Grand Cherokee Logo
Posted on Dec 14, 2008
Removal of dash and factory stereo
I have a 2005 Jeep Grand Cherokee. 6 disc player model RAQ without navigation. i want to install a part a bought online for my ipod. How do I remove the dash portion over my radio? Thanks!
  • Anonymous May 11, 2010
    I have no idea, but i would like to ask you about the performance of the vehical, i have a 2005 jeep cherokee standard 6cylinders laredo, does your jeep dash flash off and on at random time through the day,it didn't start out like this but gradually got worse till it does it all the time. I need to know if yours does the same thing or has it ever done it, and what do you think is the cause.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
896
Points
This is an easy fix. Use a flat head screwdriver andpry out the center stack where the heating and air controls are. this will just pop out. From there there are a few screws to to remove to get the cover off around the stereo.
Disc player not working 2014 grand cherokss jeep
Replace the stereo in the Jeep.
Aftermarket or factory your choice.
There is no way to self resolve this problem...
And any junk yard stereo you buy will need an activation code. Just buy a good Pioneer or Kenwood stereo and install it. Problem solved. No more BS
I have a 2005 Jeep grand cherokee...with a 6 disc cd player. It has worked fine for 3 years since i bought the vehicle...(i used burned cds in it usually) and all of a sudden it will not play or read the...
this is a typical problem with the factory stereo. usually there is nothing you can do for the Cd player, because most likely a cd got jammed and broke or bent some internal components. however try usig a credit card to help eject. insert it partially into the slot and pull out if the cd tries to come out. if this doesen't work then you will have to have the cd removed by tearing it apart. this usually ends up with at least one or two scratched cds and a deck in a million pieces.
How do you take of the dash paneling to install a new aftermarket cd player?
  • Disconnect the negative battery cable from the Jeep Cherokee battery with the 10 mm wrench.
  • 2 Remove the five screws on the top edge of the dash panel with a Phillips-head screwdriver.
  • 3 Pry the trim panels surrounding the climate control knobs away from the dashboard with the trim panel removal tool.
  • 4 Remove the trim panel that surrounds the headlamp switches (located to the left of the steering column) with a trim panel removal tool.
  • 5 Remove the two screws behind the trim panel that surrounds the headlamp controls with a Phillips-head screwdriver.
  • 6 Pull the dash panel that surrounds the stereo and covers the instrument panel of the Cherokee, away from the dashboard by hand.
  • 7 Remove the two screws from the stereo mounting bracket. One screw is on the bottom left corner, the other screw is on the top right corner. Each screw can be removed with the 10 mm socket and drive.
  • 8 Pull the factory stereo from the stereo mounting dock.
  • 9 Disconnect the stereo wiring from the back of the factory unit.
  • 10 Connect the Jeep Cherokee factory stereo wiring to a wiring harness adapter. Connect the wiring harness adapter leads to an aftermarket stereo. Slide the aftermarket stereo into the stereo mounting bracket and replaced two screws at the opposite corners with the 10 mm socket and drive.
  • 11 Replace dash panel that stretches across the top of the steering column.
  • 12 Replace the two screws at the top of the headlamp control switch. Replace the trim panel around the headlamp switch.
  • 13 Replace the trim panel that surrounds the climate control knobs.
  • 14 Replace the five screws on the top edge of the dashboard with a Phillips-head screwdriver.
  • 15 Replace the negative battery cable over the negative battery terminal and tighten the cable to the negative lead post with the 10 mm wrench
  • 0helpful
    I want to install an in-dash navigation systen in my 2005 jeep grand cherokee lorado. hw do i find out what type fits best and will work best with this car? help!
    best way go to a auto stereo shop see what brands and sizes they have to fit jeep, also they may know best location for it. also what kind of installation kit you may need, good luck.
    2helpful
    2005 Jeep Grand Cherokee Ltd - Navigation System error
    They did have problems with the disk and radio.Jeep has an updated disk(it happened to my brother).
    How do I remove the radio on a 2005 grand cherokee?
    If its not responding at all, you will have to remove the unit and take it apart until you can remove the disc's by hand. You can either put it back together and just use the radio or replace it with oem or aftermarket deck.
    Replace stock cd player from one brand of car to another.
    Check at stereo sales/install place, or most auto parts stores have them now, and ask for adapter for wiring & plate for mounting in what ever vehicle you decide. It makes things a lot neater, & easier. Take player in with you to make sure, mounting plate is correct.
    6helpful
    Eject navigation disk in 2005 Jeep Grand Cherokee
    Under the cd slot you will see a long thin rectangle that can be gently pryed out with a knife tip on the right side of the rectangle. under that cover there is a small button. push that and out comes the nav disc. Voila solved
    6helpful
    2answers
    Can not set the clock on my 2005 grand cherokee limited
    im a tech at a jeep dealer and i always have trouble remembering how to set the time. but i do know that it is in the navigation menu somewhere under settings or something i hope this helps
    1helpful
    2005 Jeep Grand Cherokee Ltd Navigation DVD Hemi
    R U REMOVING THE SML PLASTIC COVER AT THE BOTTOM OF THE NAVI UNIT. SML POCKET SCREWDRIVER WILL WORK JUST BE CAREFUL NOT TO BREAK COVER. I DID MINE IN THE PARKING LOT OF DEALERSHIP WHEN I BOUGHT A USED 05 G CHEROKEE.
    Top Jeep Experts
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Thomas Perkins
    Thomas Perkins
    Are you a Jeep Expert? Answer questions, earn points and help others
