Question about Lionel Cw 80 Transformer
Lionel train power issue
We are trying to set up a refurbished lionel train set. We have the copper wires in place and the lockon connected to the tracks but we cannot get the transformer power to connect to the train power.
  • 1 more comment
  • Anonymous Mar 21, 2014
    Was the name of the gospel song sung my Lionel Ritchie entitled Jesus Is Mine?
  • Anonymous Mar 23, 2014
    These engines have not been operated for over five years, they respond to TMMC Railsounds but will not move, I tried to lubricate the gears, but cannot move the wheels.
  • Anonymous Mar 26, 2014
    lionel transformer green light flashes, train doesn't move
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
  • Gerald Lewis Sep 05, 2011
    Sounds like the tracks are connected to the CW-80 aux connections not the train connection and that the aux voltage is fixed programmed to 0 or a very low voltage. This is a common mistake when hooking up the CW-80.
    Problem Solver:
  • 13 Answers
Bad connections, wires to/from the transformer, or maybe a real dirty track.
try spraying a very small amount of CRC [brand ) 226 it is better than any contact cleaner on the market. do not get it on the rubber traction wheels on the engine. If you do, wash off with alcohol using a cotton swab on the rubber band on the traction wheel....
check the voltage on the transformer with a multi meter should be 3 to 14 volts .
if that is ok, ckeck voltage on the rails, if that is ok, it is the switch unit on the engine. Again, find the switch, with a spray tube that came with the CRC 226, spray a small amount og the contact area[ this is called an "e-unit switch " and are 90% of the electrical source problems on the older engines,,BUT all are repairable !!!!
Posted on Nov 20, 2011
Lionel o guage polar express set transformer has a bell button but don,t work no sound
IfIam correct, the basic Polar Express came with just a whistle. There is an optional coal tender that has a better sound system in it...Whistle bell and steam sound also try reversing the power wires at the transformer or track
Mar 11, 2014 | Lionel Trains The Polar Express O Gauge...
Can two tracks be powered with the Lionel Trainmaster R 100 Watt transformer?
Track 1 as you have it connected is terminals B-F. The second track would be terminals B-C. Connect post B to the outer rails Terminal 1 ? on your lockon. THis will give you 6-16 volts at the track.
Dec 01, 2013 | Toys
Check out these Lionel Customer Service Videos.
Dec 31, 2012 | Lionel 6-30068 North Pole Central...
Lionel train wheels are locking
1: clean & lubricate your engine2: if that does not work, the wheels may be out of quarter,check with Lionel Parts & Services.
Dec 22, 2012 | Toys
What guage wire should I use to connect a train transformer to the O gauge lockons on the train track? thank, E.S
I have used 18ga lamp wire but you can use wire as thin as telephone wire. My rule of thumb is to use thicker wire (lower gauge number) the more motors on the train you are running. 20 or 22ga is generally used by most.
Jul 05, 2012 | Lionel The Polar Express Train Set
My new lionel train slows down on far side of the track
There is bad contact in the track connections. You can sand the track connection sites. Another method is to run another power wire to the other end of the track where the train slows down. Even better is 3 or 4 evenly spaced power wires from the transformer to the track.
Jan 26, 2011 | Lionel New Haven Freight Train Set
I have Lionel Fastrack 048 switch. I extended the controller wire and all of my slices are perfect. The switch operates but the light in the controller does not operate - neither red or green. I checked...
You will need to check continuity of the yellow RSC wire from inside the controller to where it enters the switch connection block. Neither light will work if this wire is broken.
2nd: Lionel quality control is so poor that if that is not the problem, remove the plate from the bottom and make sure the five plugs are firmly in place on the electronic board. Since both green and red do not work it is most likely not the micro switchs but an issue with the circuit board.
Jan 01, 2011 | Lionel Fastrack O36 Manual Right Hand...
Connect the lionel ctc lockon to the track
The lockon is for tubular O or O-27 track. Slide the large part of the clip over the bottom flange of one outer rail....straight track works best and snap the cmaller clip onto the center rail. the two small terminals are your wire connections.
Nov 23, 2009 | Toys
Lionel Cw 80 Transformer Logo
1,688 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
