Acer Extensa 5620-6119 Notebook Logo
Posted on Dec 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My laptop just freezes when working with it. i get a blank screen and the laptop freezes. sometinmes i get a blue screen and it just switches of
Anonymous
Level 2:
Sergeant:
  • Expert 324 Answers
  • Posted on Dec 14, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
324
Questions
Helped
202568
Points
697
There are quite a few things that could cause this to happen. So, let's start with some basic possible fixes.
1) You could have a static build upon the mother board. Remove the power plug and battery. Hold the power button on for at least 30 seconds. That should drain the static.
2) There could be a connector problem. At very least,remove and reinstall the HD, DVD drive, memory modules,any PCMCIA cards flash drives, external drives and so forth.
3) If you have the tools and ability, I would suggest opening the beast up and reseating any connector that you can find including the wireless card and the CPU.
40 I hope not, but you could have a flaky mother board.
As I said, these are pretty basic ideas and hope that I've been of some help.
Let me know how you come out, or if you need more help.
Thanks and have a super day!
Ron
Trying to restore my acer laptop in safe mode but it freezes on a blank blue screen.
Hi
i would be tempted to take the hard drive out from the laptop while switched off
then put it back in again
i have know this to help before on several occasions
its normally in a compartment on the bottom of the laptop with just a couple of screws to remove
When i switched on my laptop it powers up okay then just goes blank with a blue screen
Hi there !
Blue screen means that your hard disk drive is damaged and cannot be repair or reformat. But still to repair or run windows operating installation on your CDROM and maybe it is repairable. Other you need to replace your hard disk drive to work again your computer.
Good Luck.
Dell M2300 issues: After several times of a freezed screen & rebooted the computer while either on the internet or working with "Autocad Inventor", it's finally gave up on me, on the last...
Isolate where the problem is: it could be the LCD display or the graphics circuit on the main board. Connect the VGA output of the laptop to an external monitor - one that you know is good. From the function keys, activate the VGA output of the laptop - it's suppose to switch between the LCD display or to the external monitor. Switch it to the external monitor. If the external monitor works, then you have a problem with the LCD display of the laptop.
2answers
Blank screen on Toshiba Laptop
you may need to restore the computer. any questions you can email me at [email protected]
My compaq evo n1020v freezes,on restarting blank screen
First conclusion: This is not a software fixable problem. If your notebook is still in warranty, I suggest you to RMA it. No doubt somethings broken.
2helpful
Blank light blue screen (NOT blue screen of death)
hi...some times norton uninstallations create this problem, in which norton also uninstalls some system file like virtual driver file, etc.! u can try these things :
1. use systen restore to restore ur previous settings
2. IF it don't works, reinstall window !
let me know if it helps....
2helpful
2answers
Laptop boots up intermittently or screen freezes
basing on the information you have given here are the possible solutions:
remove any external device connected to your system (printer, external hard drive and others) if removing this does not work and still gets a blank screen with blinking cursor try to go to safe mode with networking. if successful try to download the driver for your video adapter.
when you try to start the computer , do get anything on the screen like a logo? when does the blank screen occurs, is it during the turning ON of the computer or during the windows xp logo appears on the screen?
a blank screen could be caused by the following: defective video adapter, corrupted video driver, defective memory, unknown device causing the issue like the hard drive, optical drive or other peripheral installed inside the computer.
try also using an external monitor
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
