Question about Sony Xplod Car Audio CDX-F7810 - CD/MP3 Player
FM Radio won't work on my Sony Xplode XR-C5300X
Before putting my truck in storage for 2 years the cd, cassette player, am/fm radio all worked. Now everything but the fm radio work. I checked to make sure that the antenna was connected and working but still all I get is static from the fm radio. Anyone have any sugestions as to what the problem could be.
  • jl119006 Mar 13, 2009
    The cd changer works fine, but I can't get ANY radio. The antenna is connected securely.
  • thospalm Apr 09, 2009
    I've had the XR-C5300X since May 2000. About two years ago I had problems with the receiver. I get about 15 minutes of radio then the sound cuts down to barely audible. If I turn the volume WAY up then I can hear, but then every now and again the volume would return to normal and blast for about 5 seconds.
    New Friend:
Same issue here, hardly used the unit, and have no radio reception, all else works including the CD changer
Posted on Mar 13, 2016
  • 78 Answers
SOURCE: Sony Xplod no radio in 2000 Ranger
if you have lost am and fm it sounds like the antenna connector on the back of the radio has come off, if you find that is the case put it back on and secure it with a strip of tape
Posted on Dec 19, 2007
SOURCE: No AM or FM yet cd player works
Friend,
Maybe, there is a problem from the detector of you radio function to the amplifier. Try to check on it first or try resoldering from the detector section
Posted on Mar 10, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Installing a CD player in '08 Aveo in plac eof stock AM/FM radio
You should check with Car Toys or Best Buy but you will probably need an adaptor and a wiring harness. If your doing it yourself your going to need to know how to get the stock radio out and the wiring diagram for the Aveo. Sometimes you can find the wiring diagram on Google by searching for it but usually finding diagrams for 2008 vehicles takes a year or two before it becomes available.
If your CD player has a tuner in it already you shouldn't need one. If it doesn't have one, that presents some other options.
Posted on Jun 22, 2008
SOURCE: Sony CDX-GT310. Installed by
Called a shop in VA and their opinion was that the tuner section of the unit failed. Cost of the part, $80. Then, labor and shipping. I can buy the new model (GT320) for about $95. I opted for buying a new unit.
Posted on Aug 12, 2008
SOURCE: to install sony car cd/mp3 player removing the FM cassette player
how to connetct stereo system
Posted on Apr 13, 2009
Lost sound on 2005 impala. radio works. seems like amp problem.
Do you have base or up;level system ?
Table 1: Radio Features
Table 2: Cassette Features
Table 3: Compact Disc Features
Table 4: XM Advisory Messages
The radio receives power from the RADIO fuse in the junction block-right I/P. Ground is provided via G201 and G202. The radio is enabled/disabled by class 2 messages from the body control module (BCM). The radio routes audio signals from the digital radio receiver or the vehicle communication interface module (VCIM) to the speakers and/or amplifier when directed by class 2 messages.
The Entertainment System on this vehicle is configured with an AM/FM stereo radio with the radio data system (RDS) and either a cassette player or a CD player or both. CD and cassette. The uplevel system provides the customer with extended range speakers and an audio amplifier. Satellite digital radio (U2K) is available with uplevel systems.
The following list shows the radios available for this vehicle:
• Radio (ULO) - AM/FM Stereo, Cassette with RDS
• Radio (UNO) - AM/FM Stereo, CD and RDS
• Radio (UPO) - AM/FM Stereo, Cassette with CD and RDS .The complexity of the radio systems on these vehicle is mind blowing .
Your best bet take it to a GM dealer , has features you are unawear of .
DTC B1025, B1035, B1045, or B1055
When the radio is powered up, the radio supplies low level audio signals to the speakers. If the vehicle is equipped with an audio amplifier, the amplifier will boost the signal sent to the speakers.
DTC B1025 Audio Output Circuit
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, monitor the DTC Information for DTC B1025.
Does the scan tool indicate that DTC B1025 is current?
Jan 31, 2017 | Cars & Trucks
I was attempting to install a new stereo in my 2000 taurus. it requires to an adapter to put the new stereo in. i got the new adapter and stereo in *kinda* but decided i didnt really know what i was...
check your fuses first. You may have blown one.
Visual Inspection Chart Mechanical Electrical
  • Integrated control panel (ICP) physically damaged, misaligned, any control(s) inoperative
  • Digital audio compact disc player physically damaged, misaligned, any control(s) inoperative
  • Antenna or antenna cable physically damaged, misaligned connection(s)
  • Radio speakers, mounting/speaker cones physically damaged, misaligned
  • Radio ignition interference capacitors, radio frequency interference suppression bond misaligned (also check for cleanliness and metal-to-metal contact)
  • Battery junction box (BJB) fuses F127 (5A), F117 (20A), F127 (5A).
  • Central junction box (CJB) fuse F227 (10A) F211 (15A), F216 (15A), F226 (10A) (wagon only)
  1. If the fault is not visually evident, proceed to diagnose the integrated control panel (ICP) by entering the ICP Self-Diagnostic Mode.
NOTE: To enter the ICP Self-Diagnostic Mode, the ICP must be ON and in radio tuner mode (AM/FM).
  1. Enter the diagnostic mode by pressing and holding preset buttons 3 and 6 simultaneously. This will suspend all radio functions, and display SP.
  1. Preset Button 1 = Audio internal/external SELF TEST. The display will flash SELF while gathering the diagnostic trouble codes (DTCs), then stop flashing when complete. Press the TUNE UP button to display the DTCs if any exist. Record codes and refer to the following table:
ICP SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit (RCU) 2 No response from cassette player 3 - 4 No response from compact disc player 5 - 6 - 7 No response from remote climate control 8 - 9 Read Only Memory Verification failed
  1. Preset Button 2 = Displays the feature strap for code identification, refer to the following table.
Code Description 01 Base-Electronic Search Radio (ESR) with Manual Climate Control (MCC) 07 Electronic Search Radio with Cassette (ESC) with MCC 17 ESC with Electronic Automatic Temperature Control (EATC) 97 Not programmed default of ESC with EATC
  1. Preset Button 3 = ICP and RCU identification. This test identifies the software level of the ICP and RCU. The ICP is tested first, followed by the RCU. The display will have two sequences of three codes each. The first sequence is for the ICP, the second sequence is for the RCU. For code identification, refer to the following table:
Item Part Number Description 1 - Product variant code 2 - Tape model 3 - CDR
SOFTWARE IDENTIFICATION CODES Product Type Code Description Product Variant Code Description 21 ICP 07
08
09
10
11
12 EATC with AM/FM, cassette player and CD changer
EATC with AM/FM and cassette player
Manual A/C with AM/FM and cassette player
EATC with AM/FM cassette player and CD changer 31 RCU 01
02
03 Analog
Digital
Midline 71 Remote climate control 01 LH drive 52 Compact disc/disc jockey 01
02
03
04 Sony® 10 disc
Sony® 6 disc
Clarion® 6 disc
FMS 6 disc
Sep 13, 2011 | 2000 Ford Taurus
Sony walkman fx281 says hold when I push AM or FM button How do I turn on radio?
Srt HOLD switch to Off position as shwon in below image so Radio will start work.
Thanks.
Feb 05, 2010 | Sony Walkman WM-FX281 Personal Cassette...
Trying to install Roady 2
If the Roady2 has a fm modulator built in, you can go to the menu and set the fm frequency. If it doesn't, you could use a fm transmitter that they have for mp3 players to listen to in the car
Apr 13, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Sony CD Walkman-(portable Radio -CD player)Very low sound output.
Problem solved by trying another set of headphones.
Thanks anyway.
Gerda
Apr 05, 2009 | Sony (Personal Audio) Walkman AM/FM Stereo...
Sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 19, 2009 | Sony XPlod CD Player w/MP3 Playback...
Car cassette player
yes the rubber rollers inside your unit have become hard,,and they are slipping, and the unit detects this,, u can purchase a product called re-grip [ for rubber products and it treats the rubber in such a way to make it soft and pliable again ] the product is sold by mcm electronics and can be found online,,, treat the surfaces of the rubber rollers in your unit and it should preform to original specs....any further help please email me at troublerst@hotmail.com...i hope this helps you
Jul 03, 2007 | Sony XR-C6100 CD Changer
Sony Xplod Car Audio CDX-F7810 - CD/MP3 Player Logo
627 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
