Question about Adobe Photoshop 7.0 for PC
Kontas KTS-02 watch..instructions are not clear
Hi.Im not sure if anyone can help but i just bought the above watch and it came with one sheet of instructions which arent clear at all. I cant set the time, date etc. I have changed the anolog time but the digital display etc but i cant get the digital displays to make any sense. My old watch would show the date, month, day and time in digital & anolog. can anyone help as its driving me mad. Thanks
  • Sean Cole
    Sean Cole May 11, 2010
    Try posting this on another forum, possibly one to do with watches.
3 Suggested Answers
SOURCE: kontas watch manual
I have just figured this out on my own KTS01, it should work for all models press the button next to 4pm and hold down, then press the button next to 2pm. You should here a beep this will have turned off the alarm and the hourly beep. Repeat the process to turn it back on. Hope this helps.
Posted on Mar 30, 2008
tung aje mir qapo ban ahaa
Posted on Jul 23, 2008
Was is F 02
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | Kenmore Elite 45986 Front Load Washer
F 02 flashing on washer
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
May 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
No Instructions
Peg out the "brown" ground sheet of the inner tent and hold it up like a standard ridge tent.
Put the two shorter upright poles on the inside of the compartment (with something under the feet to prevent damage to the ground sheet). Put the 40mm tubes on the spike that pokes through, and then put the ridge pole on the outside.
Everything should then hold in place while you put the fly sheet over the top with the 2 longer poles at the front.......
tip - line up the seam on the fly sheet with the front of the inner tent as you peg it out....
Good luck
Mar 21, 2009 | Sport & Outdoor - Others
Set time/date How??
Follow this link:
http://www.tissot.ch/index_offer.php?c=eu&l=en
Find and download instructions for your watch. Site is quite complicated, but you will find all the info you need if you've got patience.
Rate me, please.
Mar 14, 2009 | Tissot T33.1.588.71 Wrist Watch
Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Aug 08, 2008 | Fossil Philippe Starck PH1035 Wrist Watch
Kontas watch manual
Jan 16, 2008 | Adobe Photoshop 7.0 for PC
No instructions
I just bought the same watch for my son, and it also came with no instructions. I can't figure out how to set the time.
Dec 12, 2007 | Watches
Adobe Photoshop 7.0 for PC Logo
279 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
