Question about Philips Magnavox TP3285C 32" TV
Need a lil help with a TP3285 C129
I accidently changed the Option byte values now I have no sound.. set is forced into MA "mono all" mode and no sound at all.
Sound worked fine before I fudged the values.
Help! please
The tv is on Mono and wont budge there is a picture but not sound no remotes will work..wont even turn off by the base or remote its frozen. what do i do.. I dont even know how old it is..
Posted on Jan 12, 2010
I have a 2009 Samsung LCD tv that has worked fine for years. I'm not sure if holiday tenants have played with settings, but now the volume when set to TV is way too low and hard to hear even on Ma
It sounds that somebody have entered into its service menu options, and changed the data values to audio settings there. You must get into its service menu again and must adjust these data values to its original factory settings. you needn't open the set, but the work is somewhat skilled one.
If you wish to get more details about how to its service mode, and make it to factory reset, check this link. Details are there. Be sure that you can do the adjustments, before adjusting any data values there. Do not tamper with it. If you're not sure, seek help of any experienced service technician.
Feb 05, 2013 | Samsung LN32A330 32 in. LCD TV
Tip
SERVICE MODE TO BEKO 23WL46G 30WL46G
Service Menu StructureThe service menu has three items: display, calibre and version 2.1 Display Display item has seven options:
a- Panel
Panel option gives information about the current panel resolution. It is a read only option and can not be set.
b- Power on time
Power on time gives information about the last update time of the SW running. It is a read only option and can not be set.
c- Backlight on time
Backlight on time option reserved.
d- Scart prescale
Scart prescale option sets the prescale values for the input sounds entering the scart input of the MSP(Micronas Sound Processor). Changing this value you can adjust the level of the output sound going to loudspeakers for all the sources except the Tuners. The range is between 0 and 100.
e- nicam prescale
Nicam prescale option sets the prescale values for the Nicam standard sounds for tuner inputs. Changing this value you can adjust the level of the output sound going to loudspeakers for Nicam sounds entering the analog sound input of MSP. The range is between 0 and 100.
f- fm/am prescale
fm/am prescale option sets the prescale values for the FM/AM standard sounds for tuner inputs. Changing this value you can adjust the level of the output sound going to loudspeakers for FM/AM sounds entering the analog sound input of MSP.
g- Agc(Automatic Gain Control) adjust
Agc adjust option sets the input voltage going to IF decoder AGC pin. Changing this value you can adjust this voltage for optimum Tuner performance. The range is between 0 and 31.
h- R/G/B Brightness/Contrast:
These are used for color bias adjustment. The range is Between 0 and 255
Calibrate
Calibrate item has nine options:
a- video format
Video format option force the video format to the desired format. Selectable formats are Auto, Pal, NTSC and SECAM.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
Ajin Gopakumar Google
on Feb 16, 2015 | Beko 17WLB450S 17 in. LCD TV
Accidently pressed a button and lost sound on my 42
Go into customer menu and look both in setup and audio menus.
In set up are speakers switched on or off?
In audio menu which sound mode is selected? (Mono-stereo-sap)
Mar 16, 2012 | Televison & Video
Can't change from MONO to AUTO mode
Hello
Can't make sound from mono to auto is your problem I thinks and posts this solution.
Hit the "Menu" button and surf through, come to "Sound Adjust" window.
The settings allow you to change and adjust sound in your TV. There are Bass, Treble and Balance control to adjust to your individual taste.
To adjust them
1. Press Menu button.
2. Press UP or DOWN button to select the desired item.
3. Press => or 4. Press EXIT button when finished.
When adjusting the parameter of "Balance" control, always set it to mid position to get stereo sound from both speakers. If it is set to any extreme end, there will be no output from the speaker of that side, and will hear as mono.
If you press "0" [Zero] button, you can reset the sound settings to it Factory settings.
To select 'Streo mode;
1. Press "Menu" button.
2. Press UP or DOWN button to select MTS [Multi-channel Telivision Sound].
3. Press => or [The ON AIR arrowtells you if a broadcast is in stereo AND/OR contains the SAP.
Press "Exit" button when finished.
Keep the TV in stereo mode to get the best sound quality. The sound will work in stereo
mode even if a certain broadcast is in mono sound only.
Choose the mono setting to reduce excessive noise on a certain channel or broadcast.
Selecting SAP will allow you to hear an alternative soundtrack, if one is available.
Apr 01, 2011 | JVC AV32F476 32" TV
Phillips Eye Fi television sound not comming, momo
enter serv mode by following sequence
062596 display or menu
check option bytes , opt byte sticker is pested on crt or backcover correct the values problem will be solved
Jun 29, 2009 | Philips Televison & Video
Akai PT5250A - I cannot converge correctly.
this fixed this problem
Plugs on the chassis coming from keyboard and side video input are switched (they have same plug)
redoo convergence save and auto focus in factory mode after switching plugs
Jan 13, 2009 | Akai PT5250A Television
HP Laserjet 1320 Printer
Hello
Please note: Instructions only applicable to the network printer which supports telnet protocol.
HP Mono and Color LaserJet Network Printers - Sleep Mode Problem
Issue
Network printers may not print when a job is sent to the printer while in sleep mode.
Solution
Please follow the steps below-
1. Connect the printer to telnet- Using command prompt.
2. Type telnet > IP address press then enter.
3. Type menu and press enter.
Following screen will appear-
4. Choose option 2 TCP/IP menu and press enter,
5. Choose option 5 TCP/IP other settings and press enter.
6. Type y in front of cursor and carry on pressing enter until you reach “SLP keep alive”. By default this value may be 0.
7. Change this value to 1.
8. Exit and save settings.
- Nikhil
Mar 04, 2008 | HP LaserJet 1320 Printer
POWERS DOWN AFTER 4 SEC
crt beam current too high causing shutdown as you know. Check cathode voltage of each cathode, normal levels depend on picture is around 130-150V. Missing 200V to crt board. Screen voltage problem normal 300-500V. Flyback or bad crt. ABL circuit problem. Jungle IC.
Oct 29, 2007 | Philips Magnavox TP3285C 32" TV
Power light flashing/blinking on the BEFSR41 V3
This is caused by the firmware not loading correctly. Follow the steps below to fix this. 1. You will need to gain Internet access to download the latest firmware for your router. The firmware must be present on the computer that will do the upgrade. Temporarily bypass the router and plug directly into your Internet Service Provider?s modem to gain access, or use another location other than your own to get to the Internet and download the firmware. 2. Download the latest firmware for your Router from http://www.linksys.com/download/firmware.asp. Select the model number of the Linksys router you have. Be sure to select the correct router version (BEFSR41 V3), as firmware upgrades vary by version. 3. Click the ?Get Upgrade? button. 4. After the firmware page opens, click the link that says, ?Click here to download the latest firmware...? and download the firmware file. Once you download the Zip file, unzip it and extract all files. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. Before performing the upgrade, assign your computer a static IP address. For more information, please see Answer ID 534 for instructions. If using a 10/100-network adapter, change its speed to 10Mb, half duplex. For instructions on doing so: Windows 95/98/ME 1. At the Windows desktop, click on Start then choose Settings and click on Control Panel. 2. Double click the Network icon. This will bring up the ?Network Configuration? window. 3. Locate and highlight the icon with the green logo for your network adapter and click Properties. 4. This will display the network adapter's Properties. 5. Select the Advanced tab and click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Once this has been changed, click OK to return to the Network configuration screen. 8. Click OK again and Windows will ask to restart your computer. Click ?Yes? to restart. Windows 2000/XP 1. Go to Start click on Run and type in control ncpa.cpl. 2. Double click on the Local Area Connection that controls your network card. 3. Click Properties under Local Area connection status. 4. Click the Configure button. Then, click on the Advanced Tab. 5. Click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Click OK after you made the change then click Close. Reloading the firmware 1. First, hold the reset button located on the back of the router for 30 seconds. 2. Next, to test communication between the Router and the network card: Go to Start, and select Run. Type in command and press [Enter ]. This will bring up the MS-DOS prompt window. 3. Type ping 192.168.1.1 and press [Enter ]. 4. You should get the following results: Pinging 192.168.1.1 with 32 bytes of data: Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL= 128 5. Once you get these replies, close out of the command prompt by typing in exit and pressing [Enter ]. 6. You may now proceed to upgrade the router?s firmware with the files that were downloaded. 7. Once the upgrade is complete, the router's Power light should no longer be blinking. Note: Be sure to go back to your network card settings (from the steps above) and change the speed of the link back to ?Auto sense? or ?Auto? (the original default setting) to restore full speed to the adapter. If any of the steps do not work, or if you are having other difficulties, please contact Linksys Technical Support for further assistance.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Red Diag light blinking on the BEFSR41
This is caused by the firmware not loading correctly. Follow the steps below to fix this: 1. You will need to gain Internet access to download the latest firmware for your router. The firmware must be present on the computer that will do the upgrade. Temporarily bypass the router and plug directly into your Internet Service Provider?s modem to gain access, or use another location other than your own to get to the Internet and download the firmware. 2. Download the latest firmware for your router from http://www.linksys.com/download/firmware.asp. Select the model number of the Linksys router you have (BEFSR41) as firmware upgrades vary by model and version (select BEFSR41, do not select BEFSR41 Ver. 3 ). 3. Click the ?Get Upgrade? button. 4. After the firmware page opens, click the link that says, ?Click here to download the latest firmware...? and download the firmware file. 5. Once you download the Zip file, unzip it and extract all files. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. Before performing the upgrade, assign your computer a static IP address. For more information, please see Answer ID 534 for instructions. If using a 10/100-network adapter, change its speed to 10Mb, half duplex. For instructions on doing so: Windows 95/98/ME 1. At the Windows desktop, click on Start then choose Settings and click on Control Panel. 2. Double click the Network icon. This will bring up the ?Network Configuration? window. 3. Locate and highlight the icon with the green logo for your network adapter and click Properties. 4. This will display the network adapter's Properties. 5. Select the Advanced tab and click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Once this has been changed, click OK to return to the Network configuration screen. 8. Click OK again and Windows will ask to restart your computer. Click ?Yes? to restart. Windows 2000/XP 1. Go to Start click on Run and type in control ncpa.cpl. 2. Double click on the Local Area Connection that controls your network card. 3. Click Properties under Local Area connection status. 4. Click the Configure button. Then, click on the Advanced Tab. 5. Click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Click OK after you made the change then click Close. Reloading the firmware 1. First, hold the reset button located on the back of the router for 30 seconds. 2. Next, to test communication between the Router and the network card: Go to Start, and select Run. Type in command and press [Enter ]. This will bring upthe MS-DOS promptwindow. 3. Type ping 192.168.1.1 and press [ Enter]. 4. You should get the following results: Pinging 192.168.1.1 with 32 bytes of data: Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 5. Once you get these replies, close out of the command prompt by typing in exit and pressing [Enter ]. 6. You may now proceed to upgrade the router?s firmware with the files that were downloaded. 7. Once the upgrade is complete, the router's red Diag light should no longer be blinking. Note: Be sure to go back to your network card settings (from the steps above) and change the speed of the link back to ?Auto sense? or ?Auto? (the original default setting) to restore full speed to the adapter. If any of the steps do not work, or if you are having other difficulties, please contact Linksys Technical Support for further assistance.
Philips Magnavox TP3285C 32" TV Logo
152 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
