Question about HP Compaq nc6000 Notebook
Laptop's primaryhard drive and multibay always on aftr switchoff
HI !!
my laptop HP Compaq nc6000
When i turn off the system the Primary Hard drive and multibay always r on (green light). i don't knw why is ths not switching off.
n the battery goes down after 20 mins and without any alert sys shuts down..
Please Help!!
Thank You
  • HP Master
  • 1,102 Answers
Control panel
screen saver
then power
then advanced in there you can make sure your options are correct
you can check your settings in there for turning off your system
ei/ when you press power button you want it to shut off
Posted on Jan 18, 2009
Why my hp compaq nc6000 laptop failing to boot from cd after selecting multbay
hi ,
go into your cmos or setup for the computer , find boot setup and change it to drive c:\ or hard drive 1 .........good luck Roy
Feb 18, 2012 | HP Compaq nc6000 Notebook
I have a NC6000 whose hard drive stopped working and I replaced the hard drive and I could not get the software to load. I replaced the motherboard and now it will load but it still is not loading al
please check whether the hard drive is loaded properly into the computer.Turn on the compupter try to go to the bios of the computer and there do the harddrive long test.if the test is failed then the harddrive has gone bad.if the test is passed then try to install the operating system with a recovery cd's.if you don't have the recovery cd's then you need to call HP to get the recovery cd's.
Nov 15, 2011 | HP Compaq nc6000 Notebook
Hi DD,
Does the cursor blink on the screen before turn off?
There could be several causes for your PC's problem.The major ones though are:-
  1. A virus invasion of your PC.
  2. Your Operating System/boot log has corrupted.
Turn on the PC and press f8 on startup.Select to open on safe mode.Choose to open on a previously good working Operating System.
If this works and the PC opens,you may have to transfer your important files to an external drive then try repairing the Operating System or probably re-install it again.But first:-
  • Check the RAM[s] and make sure they are properly seated in their slots.Your Notebook has 2 memory slots under the keyboard positioned one on top of the other.The expansion slot is the one on top of the primary memory slot.Access them by flipping over the laptop and unscrewing the back cover.There in the middle is the only compartment housing the RAM[s] and the PC's CMOS battery.Unscrew.Remove the RAM[s],clean their slots and the fix them again making sure they properly fit.
  • Check the hard disks power supply.Disconnect it and re-connect it again.
Hope this helps.Thanks!
Nov 13, 2011 | HP Compaq nc6000 Notebook
Can i burn cd in Compaq nc6000?
Only if your nc6000 came with an optical drive in the Multibay. If it did not, you have options.
1. Purchase an external USB Optical Drive. There are loads of them out there. You'll get your best pricing from online vendors. Choose a reputable one. and are well-known, but there are many others. If shopping online, I highly suggest that you read the product reviews before making a decision.
2. Depending on your exact model of notebook, you may be able to purchase direct from HP. If you will provide me with your Service Tag, Model Number and Serial Number, I'll be glad to look for you. This information is on the label on the bottom of your notebook.
Hope this helps.
Have a blessed day.
Thanks for using FixYa.
Jul 29, 2011 | HP Compaq nc6000 Notebook
Drivelock multibay password when i switch on a hp compaq nc8230
please I have my Laptop hp compaq nc8230 who requiert drivelock. anytime when I swith on I waiting for longtime.I getting a message drivelock multibay password.I don't know that I do.thank
Jul 14, 2010 | HP Compaq 2510p Notebook PC
I need bios password for compaq nx9010 plese help
y this procedure. It very serious problem. For someones...
To remove that password there are few steeps:
0. remove AC power
1. remove system battery (primary and multibay if present)
2. remove harddrive from harddrive bay
3. remove Multibay Devices from multibay
4. remove small round battery pill 3.3V, located under a cover on left side of touchpad. Remove cover gently (is no need to remove keyboard, but cover is removable with some power...) Delicate unplug small conector with cables leading to battery,
5. wait 5 minutes
6. connect AC power
7. Turn on computer unit (BIOS gets a few errors = date, time, mismatch etc. no need to panic, if everything is ok then get into computer setup pressing F10, change existing setup values as needed, if ok power down computer.
8. unplug AC power
9. Plug small battery into motherboard
10. install Hdd and multibay devices
11. Install system batteries
12. Power Up computer, there could be no password anymore
Jul 03, 2010 | HP Compaq Presario 2500 HP Pavilion ZE...
Starting problem
Starting problem Answer hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan... (More) hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan starting up with one glowing orange light next to a lightning bolt like symbol. IWhen I turn ON my laptop first time HP Compaq nc6000, sometimes the orange LED will just light up and nothing happens, sometimes when I get lucky I will be able to goto Windows. when start work properly.
Jan 31, 2010 | HP Compaq nc6000 Notebook
How to reformat my nc6000 using my os cd?
The NC6000 sometimes has trouble booting to anything other than the primary hard drive once a valid OS has been installed. If you need to reinstall by booting it USB or to a CD/DVD; this works for me as a last resort. (Especially USB which it officially isn't supposed to be able to do.)
Insert the bootable media. Shut the laptop down. Remove the hard drive - but leave it disconnected in the bay. Start the machine, let it detect the bootable device, then hot-plug the hard drive. There is some timing involved, but it works.
I loaded several NC6000 machines running Windows 2000 to Linux and XP this way.
Sep 27, 2009 | HP Compaq nc6000 Notebook
Multibay/cd/dvd access
If you look on the side edge of your laptop (more than likely the right side) you should see a CD/DVD drive bay with a small button. Just press that and it should pop out enough for you to finish pulling it out.
The other way to do it is to open "My Computer", right click on the icon that says "CD/DVD" and select "Eject".
Let me know if that helps.
Mar 11, 2009 | HP Compaq nc6000 Notebook
Boot from dvd
your linux isnt set up to boot use widows inviorment
Dec 29, 2007 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
176 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
