Question about Makita LS1013FL 15 Amp 10 Inch Dual Bevel Compound Sliding Miter Saw With Laser And Fluorescent Light
Makita ls1013fl I need instructions on how to install
The blade guard including the spring on this compound miter saw. Step by step instructions or a site that would have these would be very helpful.
Thanks
Joe
  • 3 more comments
  • jmalone1 Dec 20, 2008
    I fixed it but thank you for your offer.
    Joe
  • olddog67 Feb 06, 2009
    Difficulty in Installing Blade guard and spring on MakitaLS1013FL. Can't get the spring cocked correctly. Guard goes on ok but very little spring force after installed. Moves out of the way as you bring blade down but not much spring tension.
    Difficulty re installing blade guard correctly. Got it on and it moves out of the way as blade is lowered but couldn't get the spring tensioned correctly. Help.
  • tfranck Mar 13, 2009
    Blade guard does not fold up out of the way when cutting. It appears the metal arm that contacts the guard misses its target. Arm appears to be loose, is there a shim or washer that goes between the arm pivot and the saw body? Can't find my manual.
  • David Ford
    David Ford May 11, 2010
    Have you fixed this yet?? If not notify me and I will walk you thru it. Its not that hard
I installed it by looking at the parts pictures in the manual and experimenting. Thanks for the try at helping me.
Joe
Posted on Dec 15, 2008
How do I view the owners manual on line for a Makita LS1013 sliding miter saw
I have attached a link with the parts breakdown and the owners manual both in PDF format.
The parts breakdown should help you, if not let me know and I'll try to talk you through it.
Makita Products Tool Support
Mar 11, 2015 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
How to change a blade in miter saw
There is a button on the saw near the axis the blade spins on push the botton there should be an allen wrench that is supplyed with the saw that is mounted or stuck or attached to the saw this fits the bolt that secures the blade the bolt that holds the blade turns left handed so most bolts turn righty tighty lefty lossey this is oppisite turn it clockwise to lossen it
Dec 03, 2010 | Makita LS1013FL 10" Slide/Compound Miter...
The blade guard will not retract when saw is moved down to cut stock. Small bolt with washer and bushing fell out.......how do I repair this with out taking to a shop. Item LS1013FL
Find a small bolt and bushing...any home improvement store will have one..until you put the bolt and bushing back the blade guard won't work..this happens all the time and guy's i work with just go find a store with the same saw and grab the bolt and bushing from the floor model and take it to the counter..they will only charge you a few cents for it.
May 17, 2010 | Makita 10" Dual Slide Compound Miter Saw...
How do I install the spring after changing the blade on the Makita 10 miter saw
what spring? do you mean the one in the guard? if so you don;t have to remove it to change the blade, give me the exact model number or you can go to makitatools.com and download a breakdown that shows the reassembly of the guard, it is not that hard, and also you can download an owners manual that shows the proper blade replacement procedure.
Jan 16, 2010 | Makita 10" Miter Saw LS1030N
I need step by step on putting blade guard back on Makita LS1013
Go to Makitatools.com and in the header type in your model number and just follow thru till you can download a parts breakdown with exploded view of the guard. Just lay parts out in the order you see them and its not hard to reassemble. Might I ask what happened to guard? If you stilll have problems let me know and I will help. If I have helped you with your request would you please rate this response accordingly. Thank you.
Sep 12, 2009 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Makita 10 inch slide miter saw problem
Is this it? If not, go to Makita site & download image of your saw. Hope this helps:http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_LS1214FL.pdf
Jul 06, 2009 | Makita 10" Dual Bevel Sliding Compound...
Makita LS1013FL manual missing
Yes go to Makitausa.com and type in your model number and you can download an owners manual for the tool. Let me know if you need any more help
Feb 15, 2009 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Blade guard spring assembly for LS1011
here ya go Bob hope it helps
http://www.ereplacementparts.com/makita-ls1030n-miter-saw-parts-c-97_98_99_321.html
Jan 01, 2009 | Makita 10" Miter Saw LS1030N
Makita LS1013FL 15 Amp 10 Inch Dual Bevel Compound Sliding Miter Saw With Laser And Fluorescent Light Logo
1,195 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
