Question about Huffy Disney Princess 16 in. Girls Bicycle
Kids huffy bike
I cant' get the front wheel into the fork of the frame
  • 4 more comments
  • Anonymous Dec 19, 2008
    I have the same problem. This is the second huffy bike brand i have bought and the first one i had to return as well. It really sucks. You go through all that trouble of carrying it home and up three flight of stairs and have it not fit together!!!! then you have to carry it back again. I' am so angry!
  • Anonymous Dec 24, 2008
    Exact same problem...anyone have a resolution for this?
  • Anonymous Dec 25, 2008
    Same problem ... Christmas Eve and still trying to "spred" the forks apart ... could be a long night. Are we doing something wrong???
  • Anonymous Mar 01, 2009
    Same....Piece of junk
  • Anonymous Mar 29, 2009
    Add me to the list as well
  • Jyackle5
    Jyackle5 May 11, 2010
    Is there any way you can post pics. or send them to me at jyackle5@msn.com
    Problem Solver:
  • 7 Answers
Well forks might be bent loosen the nuts all the way off the rim now try squeezin the forks or pullin them apart depends on the problem...maybe this will help
Posted on Dec 17, 2008
  • 1 more comment
  • momwithabike Dec 21, 2010
    I just talked to customer support about the same problem. On one side, put the wheel into the fork and attach the washer that hooks on to the hole in the fork ("alignment insert") and the nut. Then use a long screwdriver or other tool to gently apply pressure to spread the fork. The other side will eventually pop in, allowing you to put on the alignment insert and nut. Do not remove the inner nuts or try tightening them to get it to fit -- I tried both and neither works!
  • Justine Trumper Dec 23, 2015
    Thank you, thank you! Night before Christmas Eve, not another bike to be had for miles around, wheel now on!!!
    Thank you, thank you, thank you!! Night before Christmas Eve, not a replacement bike to be had for miles around, but front wheel is now on!
The screwdriver tip worked for me too (I used a thin spanner). Have one person hold the wheel and push it into the slot, while another spreads the fork by applying pressure between the wheel centre and the fork.
Barry.
Posted on Feb 12, 2012
Cannot get front wheel axle into fork
Exactly what model Huffy bike do you have because it is impossible to answer without that info. Perhaps go to the Huffy website and indicate which bike it is.
If it is a basic man's or woman's mountain bike it is a very simple process.
So which bike are you having a problem with.
If you follow these instructions you will not have a problem. Copy and paste this into your browser
http://www.huffybikes.com/Content/pdf/ownersmanuals/c5f481de-b800-4803-95b8-3a18b82a824a.pdf
Dec 23, 2015 | Huffy Cycling
Huffy 12' bike front wheel doesn't fit
Mine had the same problem and there was no way bending the fork was going to work. It turns out they had installed an extral washer and nut on the axel. Take one off and retry fitting it. It may only go on one way. Make sure, before you tighten it, that the wheel turns freely.
Dec 25, 2012 | Huffy Disney Princess 16 in. Girls Bicycle
When installing the front wheel, the wheel is touching the frame. it is straight out of the box...suggestions?
It sounds like either a bent fork or a damaged wheel. To check the fork, rest the bike on a flat floor with no front wheel in, the handlebars should be in the normal position for going straight (right angles to frame), if the bike sits level, then the fork is ok.
To check the wheel, hold the hub and spin it a bit, you should see a big whobble if it is that damaged.
If it is just the wheel, you can take that back to the shop, otherwise you will have to bring the bike back, sadly.
Hope that helps.
Jul 17, 2011 | GMC Denali 700C Road Bike
I bought the huffy 16"
It's pretty hard to know how to help you exactly. But this may help--- if you have (or can borrow) a digital camera, take close-up pictures of your parts then take the camera with you to a Wal-mart or wherever this bike is sold. Compare your pictures to one on display. Or better yet, take the whole bike with you. Or just take close-up pictures of the bike on display. It might also be useful to know that the front fork (that is the two metal bars about 10 inches long that point toward the ground that the wheel attaches to) sometimes have to be spread apart just a bit to fit the wheel's axle in place. I'm talking about maybe 1/4 inch or so. If it's a lot more than that the fork may have gotten bent in shipment and you should take it back.
good luck, Merry Christmas. Al K
Dec 23, 2010 | Huffy Disney Princess 16 in. Girls Bicycle
I cant the handlebars to turnh the wheel doesnt seem to grasp am i missing a part
Tighten the 7/16 inch bolt that goes down into the neck where the front wheel attaches to the frame.
Jun 26, 2010 | Huffy 26 in. Cranbrook Cruiser Bike
The pedal hits the tire whilst turning. We just got the bikes and put them together but when you ride and try to turn, the pedal hits the front tire and causes the bike to stop abruptly.
The pedal should not be able to reach the front tire. Sometimes one gets their toes to overlap the front wheel on a racing bike but that's because they have intentionally short wheel base and a steep for angle. Which way is the fork on your bike pointing? It should be angled or curved forward.
Look at the bike icon on this posting for an example.
Mar 22, 2010 | Huffy Blackwater Men's 26-Inch Mountain...
Removing and installing a front wheel fork
Here's an article that may help on a site full of good info:http://sheldonbrown.com/headsets.html
Aug 30, 2009 | Huffy 20 In. Girls Celebration Single...
I am needing a manuel on how to put a 10 speed 26in girls bicycle together it is about a 1977
Rear wheel should be already on, put front wheel into forks and tighten nuts or quick release lever.
The handlebars should alredy be attchd to the neck. Put the neck into the frame and tighten bolt or allen head when bars are straight aligned to front wheel. Install seat and any reflectors....follow these instructions carefully cause the manual that comes w/these bikes is junk....Good Luck to you friend.....Tim
May 09, 2009 | Huffy 26in Ladies Sante Fe Cruiser Bike -...
Huffy Disney Princess 16 in. Girls Bicycle Logo
841 people viewed this question
Top Huffy Cycling Experts
Ray Capps
Ray Capps
Jeff Turcotte
Jeff Turcotte
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
