Question about Mitsubishi WD-65733 65" HDTV
How to replace the lamp on a Mitsubishi WD-65733-not cartridge
We want to only replace the lmap in the TV (can get it for over 1/2 the price of the lamp and cartridge together. Can you tell us how to only replace the bulb? (and remove the old bulb?) THANKS
  • 1 more comment
  • charly_denny Jan 22, 2009
    Did you ever find out how to replace just the bulb?
  • Anonymous Mar 22, 2009
    Want to replace the lamp in my WD-65733 Mitsubishi DLP set
  • babylingo23 May 25, 2009
    How to replace the lamp on a Mitsubishi WD-65733-not cartridge"
5 Suggested Answers
phil_frye
  • 295 Answers
SOURCE: Mitsubishi WD-65733 no picture, electrical buzzes in series
What it sound's like is that the lamp ballast is the problem. Buzzing sounds like when the power is first brought to the ballast it has to ramp up the voltage to get the lamp to light, then the voltage drops back down when the lamp is lit. Sounds like the lamp ballast isn't ramping up the voltage the way it should. May have to replace it. A good service shop would be able to do this for you.
Blessings,
A/V Media Guy
Posted on Nov 20, 2009
Testimonial: "very helpful. this was my first thought! thank you!"
  • 146 Answers
SOURCE: Mitsubishi 1080p 73'' DLP HDTV - Color distortion
You need to replace the "light engine". This is very very difficult. You need to take it to a repair shop. But this will be very expensive. Around $1,000.00
Posted on Nov 20, 2008
  • 52 Answers
SOURCE: How to reset lamp timer on mitsubishi wd-65734
This model there is no reset for lamp timer.
Posted on Nov 14, 2009
  • 476 Answers
SOURCE: Mitsubishi wd 65733: new bulb, 1 month ago, worked
The only thing that could cause the yellow light to blink after the new lamp is that the lamp lid or access door is not placed correctly or there might be some debris between the door and the door seat to where the door sensor switch is not being activated or the switch is erratic. Try using some compressed air to clean the switch and the door seat, that might do it for you. Thanks!
Posted on Jan 08, 2010
  • 978 Answers
SOURCE: when i turn on my 64inch mitsubishi wd 65733 tv it
Good Day Judy, hi, as i see it, your 64 inch TV is on standby mode, this occurs when the Power Supply Board, (inside your TV that supplies good power from the main 220/110 v line) detected an overload, this over load can be on the power board itself or from the main board that controls the LCD screen, controls and sound, (kinda technical), replacement of the power supply board is necessary, (this symptoms are common for LCD tvs), since its a 64 inch TV, its kinda hard to handle, better call for help. Call your dealer first, ask for warranty, if no warranty, then ask for service. you can ask other dealers if they have service too. Get the best bargain. thats all. = )
Posted on Feb 02, 2010
Mitsubishi WD-65733 Red light on Replaced lamp twice
I'd just replace my lamp just three days ago and the problem still
exsist
Nov 10, 2013 | Mitsubishi WD-65733 65" HDTV
65" 1080 mitsubishi tv model# WD-65733 wont turn on
It is probably the wiring. Try buying a new power cord.
If not than it is just malfunctioned.
Contact Mistubish
http://www.mitsubishi-tv.com/contact
Nov 25, 2012 | Mitsubishi WD-65733 65" HDTV
Trouble shooting wd-65733
Mitsubishi's troubleshooting page:
http://support.mitsubishi-tv.com
Click on the "GO TO TROUBLESHOOTING >>" link.
Here are Mitsubishi's (3) downloadable PDFs for the WD-65733:
http://support.mitsubishi-tv.com/documents/WD-65733
Dec 21, 2011 | Mitsubishi WD-65733 65" HDTV
My tv color is very dim and the green light is blinking continuously
Hi! Your lamp is nearing the end of its life and needs to be replaced. You can do this very easily yourself and your manual explains how to do it. It's two screws. Order it directly from Mitsubishi. The OEM lamp costs $249. Do not buy an aftermarket lamp from an online retailer. They are of inferior quality, normally do not come with the cartridge can damage your set and they usually cost as much after you add the cartridge.
Here's the link for Mitsubishi.
WD-65733 Manual.
May 28, 2011 | Mitsubishi WD-65733 65" HDTV
My mitsubishi wd-65733 is making a strange clicking sound from behind the tv and there is no picture. then the sound goes away after like twenty seconds then will do it again pretty quick after.Any...
Lamp could be the problem or Ballast board that powers Lamp on. Encompass Parts Distribution visit their website and look up your Model#
If Problem is Lamp Mats has them for $99.00
1-800-628-1118
Oct 23, 2010 | Mitsubishi WD-65733 65" HDTV
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Blessings,
A/V Media Guy
Nov 20, 2009 | Mitsubishi WD-65733 65" HDTV
Mitsubishi WD-65733 65" HDTV Logo
2,615 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
