Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Wiring for baseboard heater
Wondering how to wire heater have 12-2 to t-stat from panel and then have 12-2 to baseboard unsure of what goes to what thanks for any info.
    Problem Solver:
  • 14 Answers
I hope you are using a Line Voltage Thermostat!! First, make sure that the power feeding the thermostat is coming from a two pole breaker of the correct amperage (20 amp). If you are using 12-2 wire with ground then please mark the white wire with black tape at each end to identify it as a HOT power source and not a Neutral wire (which is a grounded lead). Do the same for the 12-2 wires feeding the baseboard heater from the Line Voltage Thermostat. The wires from the thermostat (One Black & one White w/black tape) will be wired to each one of the two wires (one Black & one Red or two Black wires) at the baseboard heater. It doesn't matter which wire from the thermostat is wired to which wire at the heater, just as long as there is one wire to one and one wire to the other.(eg. Black from stat to Black at heater/White w/blk. tape from stat to Red at heater OR Black from stat to Black at heater/White w/blk. tape from stat to OTHER Black at heater). I have seen baseboard heaters with two black wires or one black and one red wire. Hope this helps, but if you are confused then please have an experienced tech. do it for you.
Posted on Dec 14, 2008
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
Do you have a pic. of how i hook thermo to my marley 72 inch baseboard heater , i have the mdl. fta1a the instructions show line 1 and 2 , but i have two wires on the left front that are hooked to the...
Two wires to the T-stat should go to W and C which is W for heat call and C represents common!
When the T-stat is set to heat it will connect the 24v red wire to the W terminal therfore sending 24v to the heater and the common wire completes that circuit. Make sure to use an inline fused wire to test so you do not blow your transformer. Easier to replace a fuse then a T-form
Oct 07, 2010 | Marley Electric Hydronic Baseboard Heater,...
I am trying to install a fahrenheat f2543 heater with a fta2a double pole thermostat. there is a 12/2 wire coming into where the heater is being installed. how do i connect the red and black to the white...
Hi, this is very easy for you to do.The 12/2 Romex wire coming in is the power which you know. What you do need to know, is the voltage coming in? Sometimes they will use 12/2 Romex with ground for 220, 240, operation. You need to know if the T-stat is Line voltage 220, or 240 volt. You have to have the same voltage for both for it to control. Reguardless of the voltage, lets say it is in the 220 and up range. You take one of the 12/2 wires, white or black and hook it to the black or red on the T-stat and the white to the other one, red or black. Thats it, you are done! If the T-stat is 2-pole I am sure it is a high, Line votage T-stat. Best of Luck,
Shastalaker7
Nov 09, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Where do i connect load wires to 240 volt baseboard heater
240 load goes to 240 supply if on all the time
or 240 load goes to one leg of switch other leg goes to supply
Oct 27, 2009 | Dayton G73 Utility Heater
CAN I WIRE A 2 WIRE NOMA NON PROGRAMMABLE THERMOSTAT TO A 240 V BASEBOARD HEATER AND HOW. 2 BLACK WIRES ON THE THERMOSTAT. 3600W@240 VOLT
To the best of my knowledge, Noma does not make a high voltage stat (M# would be more helpful). You most likely have a heating only stat that operates on 24VAC. Also, at that wattage, the wires on your thermostat would need to be a minimum of 12ga.
Oct 04, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Problem wiring 240amp baseboard heaters
12 gauge wire sounds under sized for the application. And 20 amp 240 v breakers might be sufficient if you where wiring the heaters separately. But be sure that your wiring is not romex - because romex is an insulator and is not permitted in conduit. I would suggest that you up size your wire to 10 guage and your breaker to 30 amp as well. Then double check your heater wiring connections to insure that they're wired the same throughout.
May 03, 2009 | QMark FBE15002 electric baseboard heater...
Dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Jan 05, 2009 | Fahrenheat Electric Convector Baseboard...
Baseboard heater
the stat points are stuck together or the stat is defective. try tapping on it to make them loosen up or replace the thermostat.
Dec 08, 2008 | Fahrenheat FBE15002 Baseboard Heater
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
1,008 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
