Question about Panasonic PT-61LCZ70 Television
I have a panasonic television that will not turn on, it sounds like it wants to. the fan is clean and all cords are plugged in correctly.
  • Anonymous Apr 03, 2009
    same
  • 13 Answers
Your "forever" LiFi lamp has gone out. Done three of these this month. Panasonic is extending the warranty on these lamps to 5 years for the part and 2 years for the labor - better call panasonic quick.
Posted on May 21, 2009
Panasonic tv model tc-21l3h with str-s6307 only sound turn on, the display no
Sounds like a cable issue. If you're using RCA then maybe your Yellow cord is not plugged in properly or at all. If it's HDMI then the cords faulty possibly! Good luck
May 06, 2015 | Panasonic Televison & Video
My friend has a WD-65731 Mitsubishi; a week ago the image wouldn't come , so he unplugged the power cord, plugged it back and the image came. But, he wasn't able to turn it off from the remote any longer,...
try this wait until the blinking stops and then press the button. if still not working replace the lamp and lamp ballast. before changing lamp make sure you clean the dust out using a compressed air.also clean the small fan over the lamp ballast.
Sep 10, 2010 | Televison & Video
Green light flashes for about a minute, fan does not turn on and there is no picture or sound.
unplug all cords and cables from tv, then unplug tv, wait about 5 min, plug tv back in this resets, the "brain" if samething ....see if your bulb is glowing, or tv is hot to touch...always clean the breather slots or holes so fan can push or pull cool air..most of these tvs have a auto shut off for safety if fan has faulted out.....you might just have a DONE fan unit.
Jun 27, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Panasonic pt56wxf95a turns itself off
Did you replace the bulb? clean dust out of fans?
Apr 17, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
Panasonic PT-50DL54; turns on and then in 5-10 seconds turns off. Replaced bulb, no help. Cleaned it out, no help. Any ideas?
It does sound like a heat related issue. What did you clean? I removed the back panel. Use compressed air to blow out all the dust from the components inside. Do not blow into the fan on the right.
I also replaced the batteries on the remote with new Alkaline batteries. Do not use rechargeable. Weak batteries can cause the remote to send POWER OFF command to the set.
Mar 05, 2010 | Panasonic PT-50DL54 50" Rear Projection...
No picture or sound?? status light flashes in four blinking intervals. I was told it could possibly be the lamp it has never been replaced.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television.IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet.NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Aug 08, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Connect home theater to tv
Do you have the cables connected to line out on tv ? Do you have the correct source and audio type selected in the home theater (analog/digital/coaxial).
Jan 18, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
TV Lamp light blinking
COULD BE FAN NOT WORKING. TAKE BACK OFF SEE IF TURNING, CLEAN THEM. GO TO SONY.COM,TROUBLSHOOTING, OR SHUT THE TIMER OFF.
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Jul 10, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony sxrd kds-r69xbr1
4 red blinks indicates a fan error. usually blowing duster inside the fan blades will cure this. there are 4 fans inside this tv. looking from the back of the tv, the large fan on the left side is usually the culprit...good luck to ya
Oct 16, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Panasonic PT-61LCZ70 Television Logo
331 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
