Cold water will come in verry slow
Cold water will come in verry verry slow the inlet screens have been cleaned still the same.the washer is an amana model number NTW5500TQO any help would be appreciated.Thanks in advance MJM
  • 71 Answers
If your water pressure is good the water valves are bad.
Posted on Dec 14, 2008
Cold water runs slow need info on how to clean
to clean those screens turn off water supply to washer pull it away from the wall about 2 feet remove hoses from back of washer and be sure to note where the hot and cold goes use a small flatblade screwdriver and pop out screen inside of where hoses attatch at back of washer if cleaning does not work the part (water inlet valve) the screens are inside of will need to be replaced this video will show you how to replace that valve
Aug 10, 2011 | Roper Washing Machines
Do the profile washers have a inlet filter for cold water.Hot water comes in fine.Cold very slow
check the cold water hose the screen in the hose to the cold water,selenoid may be clogged or have hard water deposets,just clean out see if this helps
Jul 03, 2010 | GE Profile WPRE6100G Top Load Washer
Cold water filling of tub is extremely slow. No kinks
turn cold water off and remove hose from washer,next remove the screen from the water inlet and clean it and place it back in the valve, place hose back on the inlet,turn cold water back on and test cold setting,you should have good flow.
Dec 25, 2009 | Roper RTW4300SQ Top Load Washer
Cold water trickles in slow
Your water valve is out. Call or email with brand and model number for parts. We will ship them asap for you. We hope this solves your washer problems.
Sep 07, 2009 | Washing Machines
Water on washer on cold real slow took out the screen still slow, think it mite be the solenoid.
Yes, if the screens are clean then it is most likely the solenoid, most likely on the cold water side. It can be tested for continuity with a multimeter or ohmmeter. A lack of continuity will mean a bad one and the water inlet valve assy will need replaced. Best wishes.
Aug 21, 2009 | Washing Machines
Very slow cold water fill, why?
First make sure that you have adequate water flow from the hose bib coming from the wall. You can do this by turning off your cold water connection at the wall, then disconnect the cold water hose. Then turn the faucet on and make sure the water flows freely. The most common reason for your problem is a clogged screen where the cold water hose connects to the back of the washer. To check this, disconnect the cold hose from the back of the washer and clean the small screen inside the cold water inlet on the washer.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Cold water is slow when filling for rinse cycle
Turn off the cold water.
Remove the cold water hose from the machine.
Look inside the cold water inlet on the machine and clean the debris from the screen.
Problem solved.
Feb 22, 2009 | GE WJRR4170E Top Load Washer
SLOW COLD WATER WHEN FILLING
Remove the inlet hoses.
Clean the water valve's screens.
Feb 18, 2009 | Kenmore 24902 Top Load Washer
Amana washer has no hot water - cold works fine
There is a solenoid control valve on all washing machines, located where the water hoses enter the machine. If you have a rubber mallet, you can whack the machine gently with the mallet. If the problem is resolved, it was just a stuck valve. If not, then you likely will need to replace the whole solenoid valve control. Typically there are controls for each water supply.
Dec 04, 2007 | Amana ALW880WH Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
