Question about HP Compaq nx5000 Notebook
Hp nx5000 ram problem
i m using my laptop for 5 years. Yesterday i had a problem and blue screen problem occurs(also code 7 eror) . i have got 2 * 256 kingston ram in my computer.
After this problem happens i take out one of the ram and my computer starts to work normally but now i m using one 256 ram.
i check both of my rams and they havent got any problem . how can i fix this problem permanently and use my both rams?
  • 741 Answers
There is a good chance that the error you received was because that one RAM stick went bad. You can buy one more stick of 256MB of RAM and insert it into the empty slot.
Posted on Dec 22, 2008
How much ram is supported by hp compaq nx5000? what kind of ram? thanks
MAX RAM: 2GB
RAM TYPE: DDR - 266MHz -PC2100/2700 - 2.5v
Also, you can buy RAM compatible with your laptop from HERE
Please rate my solution
Jun 21, 2011 | HP Compaq nx5000 Notebook
Nx5000: Won't power up. symptoms:battery does not start(believed to be dead). Mains power,starts up and shuts down on a continuous 3-5 second cycle, from the time you switch mains on at wall. The...
Hi whisky_zulu,
I see that you have basically done everything possible on the machine still to no avail.
Basing from what you've done still the issue is the same it shows that the motherboard on the machine needs to be replaced.
no beep codes as you mentioned indicates that the motherboard does not respond at all there maybe power but you also mentioned that it also shuts down once turned on for a couple of seconds.
replacing the systems motherboard will be the only solution to this issue.
I hope that this makes it clear regarding your query.
Have a nice day,
mvincentc
May 07, 2011 | HP Compaq nx5000 Notebook
Hi i want to remove hp nx5000 laptop cmos password
1.3 Clearing a Password
If the notebook you are servicing has an unknown password,
follow these steps to clear the password. These steps also
clear CMOS.
1. Prepare the notebook for disassembly (Section 5.3).
2. Remove the real time clock (RTC) battery (Section 5.18).
3. Wait approximately 5 minutes.
4. Replace the RTC battery and reassemble the notebook.
5. Connect AC power to the notebook. Do not reinsert any
battery packs at this time.
6. Turn on the notebook.
All passwords and all CMOS settings will have been cleared.
see service manual here
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00713410/c00713410.pdf
Mar 05, 2011 | HP NX5000 Notebook
Hi i m deepak jain...i got a hp nx5000 laptop...it automatically geting restarted...one blue screen appears with a text begning dump of physical memory.....plz can u help me out??
I think Your Os Was Corrupted So
TO Restore it
On Computer startup Press F8 Key Untill U get the Advance Start up Option There Choose Restore My LAst Setting(I forget actual Line But it was the last option )
And press Enter!!
If all well then your laptop OS will run
Else
Format Your Laptop OS And Reinstall it!!
Regards
Vikas Agrawal
MCA
Feb 07, 2010 | HP Compaq nx5000 Notebook
Hp Compaq nx5000 Laptop selft boot / restart when plueged
You need to replace the power supply, don't continue to use it for it would cause damage to your computer.
Nov 02, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
Another thought, perhaps?
ok then if problem occers then u have problem in ram so u have change the ram
Aug 05, 2008 | HP Compaq nx5000 Notebook
UPGRADATION OF RAM
Dear Sanjaykpaul.
This has to be checked with existing ram in your note book, The same type may be added to make it 512 MB or can be replaced with a new with Higher capacity. The speed should match with existing Ram Chip Module.
Best Regards
Rafique
Mar 03, 2008 | HP Compaq nx5000 Notebook
Screen issiues
y have ram problem .................try a new ram........
i m 100% sure u r problem is solved now.....
enjoy
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 26, 2007 | HP Compaq nx5000 Notebook
HP Compaq nx5000 Notebook Logo
156 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
