Question about Kenmore Elite 45986 Front Load Washer
F and then 06 error/ Kenmore elite HE 3T series 4
We are getting an F and then 06 flashing, washer stops in the middle of washing., any suggestions?
  • 1 more comment
  • ptseeger Dec 17, 2008
    not really something i could fix, but actually pointed me in right direction, have warrantly so letting sears fix it.
  • usamix99 Dec 18, 2008
    kenmore elite HE 4T error message F 06. Washer just fill's with water and will not spin. Drain's and fill's up again with water then message show's F 06.
  • Anonymous Feb 16, 2009
    f 06 is a tach sensor problem haven't found a solution yet. check the dates on complaints, these washers are going to break sears.
    President:
  • 373 Answers
Well i found the answer on browsing through fixya. the following would assist you with the needy.Hoe it is helpful.Pay back with your comments if the problem is solved.
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Posted on Dec 14, 2008
Hi, We have a kenmore Elite HE 3t front load washer. When we try to start the washer we are getting an error on the screen. The error flashes DL and then F. what does that mean? Thanks! Sabrina
'DL+F' stands for Door Lock Fault. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Apr 29, 2011 | Kenmore Washing Machines
I have a Kenmore Front Load Washing machine and I am getting an error message f-35. what does that mean? It is an HE 3T Steam. Once I get this error code, the unit stops and unlocks.
This washer seems to have multiple solutions for the f35 error,
Unplug the machine for an hour to reset the computer
Clean the filter The panel below the door has 3 screws (mine was a star shaped screw). The white cap screws off. yopu may have to cancell the error using "stop".
Please Vote !!
May 15, 2010 | Kenmore Elite 45986 Front Load Washer
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts
www.RepairClinic.com
Feb 03, 2009 | Kenmore Elite 45986 Front Load Washer
What does the F11 error code on my Kenmore Elite He 3t mean?
"F11" is a serial communications error. The following link explains the possible causes and how to troubleshoot:
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
First, attempt to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). In many cases, this is all that is required in order to correct momentary glitches with the unit. If the error code reappears, follow the advice provided in the link. In the majority of the cases, I've experienced, it was the CCU that caused the problem.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Jan 22, 2009 | Kenmore Elite 45986 Front Load Washer
Error codes f and h
I have the HE 3t and an error code of f flashes at the 9 minute mark. Can any one help with this problem? When I contacted customer service that told me to unplug the machine and plug it back in. This did not solve the problem. Any suggestions?? Thanks, Paula
Jan 17, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite Washer that does not complete the wash
The timer should be checked/replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 12, 2009 | Kenmore 22422 Top Load Washer
Lights on Front Panel Flashing
Another posibility is the door lock switch is broken. When you open the door, on the middle right hand side there should be a small pin sticking out from the washer that the door pushes on.
Jun 13, 2008 | Kenmore Elite 45986 Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
210 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
